Date/Time: Sun, 22 Dec 2024 11:39:19 +0000
ACSIL - notes on SC_NUM_DRAWING_TYPE
View Count: 711
[2015-06-23 01:41:34] |
ejtrader - Posts: 688 |
SC Team - Are there any notes available on the Drawing type - SC_NUM_DRAWING_TYPE ? Thanks |
[2015-06-23 01:56:00] |
This is not a drawing type. It only indicates the current number of drawing types.
