Date/Time: Sat, 04 Jul 2026 13:22:23 +0000
Moving Average Lines Dissapear...
View Count: 1001
| [2015-06-22 17:47:20] |
| User650681 - Posts: 9 |
When stretching out the chart the higher time frame MA's start to get truncated. Is there away to remedy this? |
| [2015-06-22 17:53:48] |
The solution to this is to load more data into the chart. Refer to this section here: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
