Date/Time: Sun, 08 Sep 2024 02:17:51 +0000
charts not updating to days loaded
View Count: 773
[2015-06-22 17:32:51] |
Crtfyd - Posts: 278 |
vs 1261 I have my days loaded to 1 Session time is set for 9:20-12:00 If I open my chart, say like this morning at 9:15. Fridays chart will be open obviously since the session time hasn't happened. When 9:20 rolls around, it just adds to the Friday chart (this happens on all days, not just today). Since 1 day is suppose to load, it should switch at 9:20 to only today loaded which it doesn't. I have to open chart settings (instead of signing out and back in) and apply 2 days then 1day to get ONLY 1 day to be loaded. In older versions it used to update the one day loaded automatically, why doesn't it anymore? Pic attached. |
Private File |
[2015-06-22 17:44:03] |
This has never been supported and there are no plans for this: Since 1 day is suppose to load, it should switch at 9:20 to only today loaded which it doesn't.
Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DaysToLoad Please do not ask us about this further. This is how it has always worked. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
