Date/Time: Sun, 08 Sep 2024 02:08:59 +0000
top step trader combine
View Count: 829
[2015-06-22 16:31:28] |
User193151 - Posts: 10 |
hello - i have login credentials for CTS but CTS is not active in my license under the DTS setting - please activate in order to use the credentials for top step trader combine.
[2015-06-22 17:58:33] |
You will require your own direct Sierra Chart account that you pay for to use CTS. Refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
