Date/Time: Sun, 20 Sep 2026 22:33:12 +0000
New PC ~ editing data to be moved
View Count: 1191
| [2015-06-22 12:50:11] |
| User96105 - Posts: 113 |
Hi, I have a new 64bit Win7 PC and I'm just looking to move the data from my old PC. But there is quite a lot of old/redundant chartbooks in there and perhaps this is a good time for some housekeeping. Can I just move the chartbooks I currently use? What is "mandatory" to be moved? Thanks
| [2015-06-22 16:29:37] |
For more information refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation You only have to copy files over if you want to preserve your current settings. As for Chartbooks, only copy the .cht files that you want to keep. Sierra Chart Support |
| [2015-06-22 20:46:43] |
Thanks Max, Which files/file types do I need to copy across to retain my global settings, graphics settings, toolbars etc etc? Thanks Date Time Of Last Edit: 2015-06-22 21:04:07
| [2015-06-22 23:32:48] |
These are the files in the main Sierra Chart folder. They are all listed at step 5 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
