Date/Time: Sun, 22 Dec 2024 11:39:28 +0000
alert problem version 1264
View Count: 815
[2015-06-22 10:33:11] |
dezorder - Posts: 7 |
Launch platforms and get as soon as the connection gets sound an alarm that keeps repeating forever. also when the order execute alert is repeated forever,, until you turn off the button -global set clear sound alert queue,, why is this happening? how to solve the problem? thanks
[2015-06-22 10:56:12] |
Go to Global Settings >> General Settings >> Alerts. Select each Alert # and make sure that the Number of Times to Play This Alert setting for that particular Alert # is set to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-22 13:46:30] |
ok ... the more alert has been no greater than 1000 ..it is automatically came alone version of 1264 ... I've entered all the number 1 ... and it's fine now ... thanks
[2015-06-22 18:02:35] |
We do not have any other reports of this and there is no known problem where the setting for the number of times to play the alert sound would change.
