Date/Time: Mon, 16 Sep 2024 19:20:43 +0000
Tool Bar keeps coming up
View Count: 787
[2015-06-22 09:00:13] |
tobi - Posts: 351 |
Just updated to prerelease version 1264 (new spreadsheets). The attached toolbar keeps coming up when starting SC, even if I had clicked "Hide Tool Bar". Please fix this. Thank you. Date Time Of Last Edit: 2015-06-22 09:03:53
toolbar.png / V - Attached On 2015-06-22 09:03:48 UTC - Size: 1.56 KB - 276 views |
[2015-06-22 09:01:23] |
We will look into this.
[2015-06-23 07:30:26] |
tobi - Posts: 351 |
FYI: Still happening in version prerelease 1265 (new spreadsheet).
[2015-06-23 07:53:30] |
We cannot duplicate the problem as we understand it. We removed all the Toolbars by unchecking them from the Window menu so they are no longer visible. When we restart Sierra Chart, they continue to not be visible.
[2015-06-23 08:13:45] |
tobi - Posts: 351 |
Ok, just figured out: - when unchecking the Toolbar from the Windows menu it works ... meaning when restarting SC it's not visible any longer - when right-clicking on the Toolbar and clicking "Hide Tool Bar" it'll come up again when restarting SC |
[2015-06-23 08:49:00] |
OK. We are building a new ToolBar/Control bar and it may be related to that.
