Date/Time: Fri, 18 Oct 2024 06:53:33 +0000
Volume up down indicator
View Count: 2328
[2015-06-21 23:30:31] |
User193151 - Posts: 10 |
Hello - is there a volume up/down indicator in SC similar to that of the "Volume UpDown" indicator for Ninjatrader?
[2015-06-22 07:23:09] |
Can you describe briefly what this does so we can provide you the proper solution or refer you to the indicator already existing.
[2015-06-22 16:33:31] |
See attached screenshot for the volumeupdown indicator for NT - do we have something similar to that in SC?
VolumeUpDown Indicator - NT.xlsx - Attached On 2015-06-22 16:33:02 UTC - Size: 166.55 KB - 446 views |
[2015-06-22 18:14:45] |
We need a simple plaintext description of what this does.
[2015-06-22 18:19:15] |
volume up down indicator makes the volume green when the bar closes up and the bar red when the bar closes down
[2015-06-22 18:31:41] |
The standard Sierra Chart "Volume" study already does this. Make sure the Subgraphs >> Volume >> Auto Coloring is set to Same As Base Graph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
