Date/Time: Fri, 25 Sep 2026 20:57:46 +0000
Possible Trial extension
View Count: 1110
| [2015-06-21 17:36:03] |
| User650681 - Posts: 9 |
Hello Sierra, I don't know if its possible to have my trial extend another week?. If so it would be much appreciated. Thank you in advance for a consideration. Susan |
| [2015-06-22 04:26:36] |
This has been done. Restart Sierra Chart.
