Date/Time: Fri, 11 Sep 2026 08:58:10 +0000
[User Discussion] - Request for Customize ToolBar
View Count: 1129
| [2015-06-21 12:24:07] |
| Marek F - Posts: 254 |
Sierra Chart Engineering, Could you please to increase a number of the Tool Config # in the Customize ToolBar # --> Tools ? Now, there is only 8, but Custom Study Button # there is 50! Usually a number of used Tool Config is higher than a number of used Custom Study Button. Thank you Marek Date Time Of Last Edit: 2015-06-21 12:24:37
| [2015-06-21 20:58:40] |
This is unlikely to be added as it involves a lot of work. It is not something we would consider at this time.
