Date/Time: Mon, 16 Sep 2024 20:10:22 +0000
JY6 (6J) tick size change
View Count: 1289
[2015-06-21 11:52:54] |
User11942 - Posts: 298 |
Hello SC team, tick size for the symbol is going to be changed today. So far I can see old tick size which is 0.000001 in my copies of SC (CQG, Rithmic). Thanks.
Date Time Of Last Edit: 2015-06-21 11:55:13
[2015-06-22 13:55:52] |
infpz - Posts: 826 |
I saw the same thing. Doing a full reset of the symbols from Global Settings > Symbol Settings did not fix the issue. However I manually made these changes and now it matches my AT DOM. See image.
[2015-06-22 19:03:05] |
This will be updated at the end of the day today. When this is done you will need to update the symbol settings as explained here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-23 05:25:31] |
The symbol settings for the Japanese Yen futures on the CME have been updated.
