Date/Time: Fri, 02 Oct 2026 16:03:09 +0000
VWAP color bar based on alart conidtion
View Count: 1516
| [2015-06-21 08:37:48] |
| Neo - Posts: 198 |
I'm trying to setup a color bar alert for my vwap study. So Using the color bar based on Alert Condition, how can I setup a color bar alert when price crosses above(SG2) or below( SG3) Thanks |
| [2015-06-22 18:46:50] |
Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html There are also examples here: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#FormulaExamples You will need to use the CROSSOVER function in the formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-06-22 21:50:55] |
| Neo - Posts: 198 |
Thanks, I managed to figure it out using separate color based alert condition studies. I'm now wondering if it's possible to combine 2 functions so an alert is true if both conditions are met within x amount of bars or time. eg "AND(CROSSFROMABOVE (L,ID1.SG5), CROSSFROMBELOW(H,ID1.SG3))" = True if occurs within Bars/time units <20 |
