Date/Time: Sun, 22 Dec 2024 05:41:12 +0000
Request for Volume By Price
View Count: 847
[2015-06-20 20:07:55] |
Marek F - Posts: 244 |
Sierra Chart Engineering, Could you please add a new Volume Graph Period Type named e.g: Multiple Profiles Fixed By Time to Last Visible Bar ? Description: 1) If there are displayed Profiles that have all Period Length, then they are displayed like Multiple Profiles Fixed By Time. 2) But, if in the same Chart there is displaying (in real time or during back scroll) a Profile that has not fully visible Period Length (not visible him End Time), then for him displaying are used for a study calculation bars from a last bar of the Start Time to the Last Visible Bar. Something like to the Type: Visible Bars but the start calculation is from the bar fixed by the last bar Start Time and not from the First Visible Bar. And correspondingly: One Period from Start Time to Last Visible Bar. These new Types will be displayed the Volume Profile, PoC, VAH & VAL, Peaks & Valleys during back scroll like it was in real time and they will fixed by the Start Time. ------------------------------------------------------------ Second small issues: 1) Does not work properly a displaying of the Value Label of the Subgraph Peaks & Valleys. 2) Does not work Extend Point of Control in the Draw Mode: POC, VAH, VAL Lines Only. But in the Draw Mode: Volume Profiles & POC, VAH, VAL Lines everything works fine. 3) Does not work Extend Value Area in the Draw Mode: POC, VAH, VAL Lines Only. But in the Draw Mode: Volume Profiles & POC, VAH, VAL Lines appear lines, that can not be change by the Subgraphs Value Area High Value and Value Area Low Value. (Sorry if I wrote incomprehensible. My native language is not English.) Best Regards Marek |
[2015-07-02 11:35:02] |
I cancel my request. I've found other satisfactory solution. Marek |
