Date/Time: Fri, 18 Oct 2024 06:46:51 +0000
Zig Zag
View Count: 896
[2015-06-20 04:31:55] |
toews&kane - Posts: 209 |
I am not sure if this is under the zig zag indicatior. I want to check if there is something like this that indicates how much volume is on each swing, and the amount of ticks on each swing? Please see attached screeshot Let me know, thanks |
Private File |
[2015-06-20 15:33:19] |
Yes, the Sierra Chart Zig Zag study supports this.
