Date/Time: Sat, 12 Jul 2025 05:58:15 +0000
Simulation on Spiders extremely slow
View Count: 918
[2015-06-20 00:34:02] |
CMG - Posts: 179 |
Hello, I am running a simulation on Spiders, and is very slow, any thoughts. Here is some data you may find useful speed 1.0x, I have 100 lines for the spreadsheet. As always thanks for your help. PV |
[2015-06-22 04:14:10] |
At a speed of 1, that would be equal to normal real-time updating speed. It should not be any lower than actual time. Is it?
