Date/Time: Sun, 08 Sep 2024 02:06:07 +0000
Real time
View Count: 824
[2015-06-19 21:10:29] |
User0945784 - Posts: 1 |
In real time, can sierra chart invoke the same sc.index more than one time? I don't know if the last value of sc.index is the one corresponding to the bar that is changing at real time or if it correspond to the last one completed.
Date Time Of Last Edit: 2015-06-19 21:12:45
[2015-06-19 21:39:47] |
Yes. As the last bar in the chart changes, sc.Index will remain the same and the study function will be called for every chart update. This is explained in much more detail here: https://www.sierrachart.com/index.php?page=doc/doc_ACS_ArraysAndLooping.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
