Date/Time: Sat, 19 Sep 2026 19:29:27 +0000
[Locked] - Chart trading order lines
View Count: 1341
| [2015-06-19 16:13:35] |
| User699694 - Posts: 49 |
Hi Is there a way to change the boldness/thickness of the lines? Thanks |
| [2015-06-19 16:36:20] |
To customize the lines, refer to the instructions here: Chart Trading and the Chart DOM: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM Sierra Chart Support |
| [2015-06-19 19:30:09] |
Hi I tried to change the p and L lines on the chart, it will only allow me to change the color not the thickness of the line Suggestions? Thanks |
| [2015-12-16 17:08:13] |
Hi is there any easy way to display only the day session? I tried ESH16.D but it does not work Thanks |
| [2015-12-16 17:41:55] |
Yes, refer to the documentation here: Chart Session Times We also see post #3 was not answered previously. The thickness of the Position Line on a chart can be controlled. This is the relevant documentation: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM The object name is "Colors and Widths for Chart Objects >> Chart Trading Position Line*" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-05 22:11:10] |
Hi is there a way to tile open windows in order of the chart no? Thanks
| [2016-01-06 03:04:34] |
Yes. This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html#TileHorizontally Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-26 15:15:48] |
Hi Where do I enter a commission value, so that it can be included in P and L? Also how does the system know that 1point in the ES is $50 Thanks |
| [2016-02-26 18:39:46] |
1. Commissions are only supported through the Trade Activity Log. Refer to the Use Commission setting here: Trade Activity Log: Controls 2. This is set through the Currency Value per Tick setting: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) At this point we are closing this thread. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-26 18:40:30
