Date/Time: Thu, 10 Sep 2026 16:37:27 +0000
chart book is not saving.
View Count: 1825
| [2015-06-19 15:28:59] |
| Robert D - Posts: 24 |
For the past three days Chartbooks that I create and save will not open? The names are in the chartbook que under the file tab. When i click I get. Error opening Chartbook file for writing. C:\SierraChart\Data\6/19.cht Error: Windows error code 3: The system cannot find the path specified. | 2015-06-19 11:17:54 * and Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\tmi.scid | 2015-06-19 11:19:18 I am doing nothing different.saves to (data.cht) Please help. |
| [2015-06-19 16:31:58] |
The issue is cause by the file name. The file name 6/19.cht is not valid, as you can not use / in a filename.
Sierra Chart Support Date Time Of Last Edit: 2015-06-19 16:34:23
| [2015-06-19 17:32:57] |
thanks
