Date/Time: Wed, 12 Mar 2025 20:15:59 +0000
How to get daily High/Low in replay?
View Count: 1220
[2015-06-19 13:36:03]
Duke - Posts: 3
sc.DailyHigh and sc.DailyLow doesnt work for replay and I would like to have the same behavior in strategy for replay and realtime.
How can I get daily high and low during replay that will work in realtime too? Thanks.
[2015-06-19 18:08:10]
These particular ACSIL variables are not supported during a replay.
You need to rely upon the Daily OHLC study and get the values from that study. Here is the documentation for that:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#UsingStudyData
[2015-06-19 20:42:13]
User650681 - Posts: 9
I have used a 1440 minute chart. For the daily chart replay. It worked for me :)
[2015-06-23 09:26:09]
Duke - Posts: 3
Thanks I have went with using sc.GetOHLCForDate as I am on minute timeframe.
[2022-05-24 00:20:49]
j4ytr4der_ - Posts: 946
This is an extremely old thread but I'm trying and failing to do the same thing, only I'm not using ACSIL. I'm simply trying to use the Daily OHLC study (as suggested above by SCE). It works fine live, but in replay all values are always zero regardless of periodicity. I can't get it to do anything in replay.
I've looked through the docs and all over Google but haven't found anything beyond this thread. What am I missing?
[2022-05-24 13:53:47]
John - SC Support - Posts: 38617
It should work just fine in replay. Please attach your chartbook with the relevant charts in it so we can see how you have this setup and what might be occurring. Refer to the following for how to attach a file to this thread:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2022-05-24 18:35:32]
Oh how odd... you're right, it works fine on a new chartbook. I'll have to look into my chartbook and figure out what's going on with it. Thanks!
