Date/Time: Wed, 09 Sep 2026 03:37:35 +0000
Lookback feature
View Count: 1658
[2015-06-18 20:58:55]
Sebastian_M - Posts: 70
Hello support,
Is there a reason why the lookback feature has no documentation?
SCInputRef lookBackInput = sc.Input[0];
lookBackInput.Name = "Look Back Bars";
    lookBackInput.SetInt(20);
    lookBackInput.SetIntLimits(1,1000);
Do I need to add anything else to use the lookback function? Examples are difficult to locate
Appreciate any help.
Regards Sebastian
[2015-06-18 22:09:12]
We do not know what you are referring to. What is "lookback feature"?
[2015-06-18 22:28:06]
Hi support,
You would use it to make a bar look back of a number of bars in the background.
But it looks like you do not have it in your library.
Thanks, I will look else where.
Sebastian
[2015-06-18 23:27:45]
Refer to this page:
Working with ACSIL Arrays and Understanding Looping
