Date/Time: Sun, 08 Sep 2024 00:17:12 +0000
Can't get 6E# to work
View Count: 896
[2015-06-18 15:12:42] |
MMX - Posts: 119 |
I've tried 6E#, E6#, neither of them will load up. For all my other weekly charts the # symbol works fine, but not for the Euro. So I'm forced to use 6E.20150900.CME_Fo with continuous contract selected for my weekly Euro. How do I get 6E# to work?
[2015-06-18 16:38:52] |
The symbol E6# should work for a historical weekly chart. - Select File >> Find Symbol. - Enter E6# into the Selected Symbol box. - Press the Open Historical Chart button. Do you see a chart open? Or do you get an error? If you get an error, post the Message Log following the steps here: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support Date Time Of Last Edit: 2015-06-18 17:51:38
[2015-06-18 17:51:05] |
The symbols that end with a #, do not work with CTS.
[2015-06-18 21:38:34] |
MMX - Posts: 119 |
CL#, ZB#, YM#, ES#, RJ# all work fine, they all load up the specified 1500 days and they all display just fine. When doing the "Open Historical Chart" a new window opens up and it is totally blank, nothing in it at all. In the Data Folder the E6#.dly is doing the 1KB thing and the message log is saying no data in the file to display and that it is an invalid symbol format.
[2015-06-18 21:42:42] |
MMX - Posts: 119 |
I missed the "post the Message Log" part of the above post. Software version: 1250 | 2015-06-18 07:15:29 Uses New Spreadsheets | 2015-06-18 07:15:29 Usage end date: 2015-06-22 | 2015-06-18 07:15:29 Enabled for: Advanced Features. | 2015-06-18 07:15:29 Enabled for: Sierra Chart Historical Data Service. | 2015-06-18 07:15:29 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-06-18 07:15:29 Active service: CTS T4 FIX | 2015-06-18 07:15:29 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-06-18 07:15:29 2015-06-18 07:15:29 Local computer clock time | 2015-06-18 07:15:29 2015-06-18 12:15:29 GMT time | 2015-06-18 07:15:29 2015-06-18 07:15:29 Time zone adjusted time | 2015-06-18 07:15:29 Time difference to server time: 0 seconds. | 2015-06-18 07:15:29 Program path: C:\SierraChart\ | 2015-06-18 07:15:29 Data Files path: C:\SierraChart\Data\ | 2015-06-18 07:15:29 OS Version Number: 6.1 | 2015-06-18 07:15:29 Locale Information: C | 2015-06-18 07:15:29 Checking for new symbol settings for cts | 2015-06-18 07:15:29 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-06-18 07:15:29 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-06-18 07:15:29 Symbol settings are up-to-date for cts | 2015-06-18 07:15:30 Files to Open on Start up | Opening file: Six MACD CCI MFI.cht | 2015-06-18 07:15:32 Files to Open on Start up | Opening file: Three MACD CCI.cht | 2015-06-18 07:15:34 Files to Open on Start up | Opening file: Three Indices MACD CCI MFI.cht | 2015-06-18 07:15:38 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-06-18 07:15:41 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-06-18 07:15:41 HD Request # 2 | Downloading Historical Daily chart data for 6E.20150900.CME_Fo. Starting date: 2015-06-17. Service: cts | 2015-06-18 07:15:42 Historical data download counter reset. | 2015-06-18 07:15:42 HD Request # 2 | Requesting historical Daily data for E6U15 starting at 2015-06-16 | 2015-06-18 07:15:42 HD Request # 2 | Receiving historical Daily data for 6E.20150900.CME_Fo starting at 2015-06-16 | 2015-06-18 07:15:43 Writing historical Daily data for 6E.20150900.CME_Fo to the file 6E.20150900.CME_Fo.dly | 2015-06-18 07:15:43 HD Request # 2 | Received 3 records from 2015-06-16 00:00:00 to 2015-06-18 00:00:00 (3.0 days) and wrote 2 records for 6E.20150900.CME_Fo | 2015-06-18 07:15:43 HD Request # 2 | Daily download COMPLETE for 6E.20150900.CME_Fo. Completion time: 0s. Unique request ID: 1 | 2015-06-18 07:15:43 Removed historical data download ID 1 | 2015-06-18 07:15:43 HD Request # 3 | Downloading Historical Daily chart data for CL.20150700.CME_NY. Starting date: 2015-06-17. Service: cts | 2015-06-18 07:15:43 HD Request # 3 | Requesting historical Daily data for CLN15 starting at 2015-06-16 | 2015-06-18 07:15:43 HD Request # 3 | Receiving historical Daily data for CL.20150700.CME_NY starting at 2015-06-16 | 2015-06-18 07:15:43 Writing historical Daily data for CL.20150700.CME_NY to the file CL.20150700.CME_NY.dly | 2015-06-18 07:15:43 HD Request # 3 | Received 3 records from 2015-06-16 00:00:00 to 2015-06-18 00:00:00 (3.0 days) and wrote 2 records for CL.20150700.CME_NY | 2015-06-18 07:15:43 HD Request # 3 | Daily download COMPLETE for CL.20150700.CME_NY. Completion time: 0s. Unique request ID: 2 | 2015-06-18 07:15:43 Removed historical data download ID 2 | 2015-06-18 07:15:43 HD Request # 4 | Downloading Historical Daily chart data for ZB.20150900.CME_F. Starting date: 2015-06-17. Service: cts | 2015-06-18 07:15:43 HD Request # 4 | Requesting historical Daily data for ZBU15 starting at 2015-06-16 | 2015-06-18 07:15:43 HD Request # 4 | Receiving historical Daily data for ZB.20150900.CME_F starting at 2015-06-16 | 2015-06-18 07:15:44 Writing historical Daily data for ZB.20150900.CME_F to the file ZB.20150900.CME_F.dly | 2015-06-18 07:15:44 HD Request # 4 | Received 3 records from 2015-06-16 00:00:00 to 2015-06-18 00:00:00 (3.0 days) and wrote 2 records for ZB.20150900.CME_F | 2015-06-18 07:15:44 HD Request # 4 | Daily download COMPLETE for ZB.20150900.CME_F. Completion time: 1s. Unique request ID: 3 | 2015-06-18 07:15:44 Removed historical data download ID 3 | 2015-06-18 07:15:44 HD Request # 5 | Downloading Historical Daily chart data for YM.20150900.CME_E. Starting date: 2015-06-17. Service: cts | 2015-06-18 07:15:44 HD Request # 5 | Requesting historical Daily data for YMU15 starting at 2015-06-16 | 2015-06-18 07:15:44 HD Request # 5 | Receiving historical Daily data for YM.20150900.CME_E starting at 2015-06-16 | 2015-06-18 07:15:44 Writing historical Daily data for YM.20150900.CME_E to the file YM.20150900.CME_E.dly | 2015-06-18 07:15:44 HD Request # 5 | Received 3 records from 2015-06-16 00:00:00 to 2015-06-18 00:00:00 (3.0 days) and wrote 2 records for YM.20150900.CME_E | 2015-06-18 07:15:44 HD Request # 5 | Daily download COMPLETE for YM.20150900.CME_E. Completion time: 0s. Unique request ID: 4 | 2015-06-18 07:15:44 Removed historical data download ID 4 | 2015-06-18 07:15:44 HD Request # 6 | Downloading Historical Daily chart data for ES.20150900.CME_Eq. Starting date: 2015-06-17. Service: cts | 2015-06-18 07:15:44 HD Request # 6 | Requesting historical Daily data for ESU15 starting at 2015-06-16 | 2015-06-18 07:15:44 HD Request # 6 | Receiving historical Daily data for ES.20150900.CME_Eq starting at 2015-06-16 | 2015-06-18 07:15:44 Writing historical Daily data for ES.20150900.CME_Eq to the file ES.20150900.CME_Eq.dly | 2015-06-18 07:15:44 HD Request # 6 | Received 3 records from 2015-06-16 00:00:00 to 2015-06-18 00:00:00 (3.0 days) and wrote 2 records for ES.20150900.CME_Eq | 2015-06-18 07:15:44 HD Request # 6 | Daily download COMPLETE for ES.20150900.CME_Eq. Completion time: 1s. Unique request ID: 5 | 2015-06-18 07:15:45 Removed historical data download ID 5 | 2015-06-18 07:15:45 HD Request # 7 | Downloading Historical Daily chart data for TF.20150900.ICE_IN. Starting date: 2015-06-16. Service: cts | 2015-06-18 07:15:45 HD Request # 7 | Requesting historical Daily data for RJU15 starting at 2015-06-15 | 2015-06-18 07:15:45 HD Request # 7 | Receiving historical Daily data for TF.20150900.ICE_IN starting at 2015-06-15 | 2015-06-18 07:15:45 Writing historical Daily data for TF.20150900.ICE_IN to the file TF.20150900.ICE_IN.dly | 2015-06-18 07:15:45 HD Request # 7 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 3 records for TF.20150900.ICE_IN | 2015-06-18 07:15:45 HD Request # 7 | Daily download COMPLETE for TF.20150900.ICE_IN. Completion time: 0s. Unique request ID: 6 | 2015-06-18 07:15:45 Removed historical data download ID 6 | 2015-06-18 07:15:45 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-06-18 07:15:45 CTS FIX - Firm: Phillip | 2015-06-18 07:15:45 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2015-06-18 07:15:45 CTS FIX socket (2) | Connected. | 2015-06-18 07:15:46 CTS FIX socket (2) | Starting SSL connection. | 2015-06-18 07:15:46 CTS FIX socket (2) | SSL connection established. | 2015-06-18 07:15:48 CTS FIX: Sending the Logon message. | 2015-06-18 07:15:51 CTS FIX: Connected to data and trade server. FIX version: 4.3.35.0 | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: CL.20141000.CME_NY. ID: 1 | 2015-06-18 07:15:51 Intraday data recording state for symbol CL.20141000.CME_NY is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: NG.20141000.CME_NY. ID: 2 | 2015-06-18 07:15:51 Intraday data recording state for symbol NG.20141000.CME_NY is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: ZS.20141100.CME_C. ID: 3 | 2015-06-18 07:15:51 Intraday data recording state for symbol ZS.20141100.CME_C is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: GC.20141200.CME_CO. ID: 4 | 2015-06-18 07:15:51 Intraday data recording state for symbol GC.20141200.CME_CO is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: ZB.20140900.CME_F. ID: 5 | 2015-06-18 07:15:51 Intraday data recording state for symbol ZB.20140900.CME_F is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: ZB.20141200.CME_F. ID: 6 | 2015-06-18 07:15:51 Intraday data recording state for symbol ZB.20141200.CME_F is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: ES.20141200.CME_Eq. ID: 7 | 2015-06-18 07:15:51 Intraday data recording state for symbol ES.20141200.CME_Eq is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: ES.20140900.CME_Eq. ID: 8 | 2015-06-18 07:15:51 Intraday data recording state for symbol ES.20140900.CME_Eq is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: TF.20141200.ICE_IN. ID: 9 | 2015-06-18 07:15:51 Intraday data recording state for symbol TF.20141200.ICE_IN is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: TF.20140900.ICE_IN. ID: 10 | 2015-06-18 07:15:51 Intraday data recording state for symbol TF.20140900.ICE_IN is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: YM.20141200.CME_E. ID: 11 | 2015-06-18 07:15:51 Intraday data recording state for symbol YM.20141200.CME_E is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: YM.20140900.CME_E. ID: 12 | 2015-06-18 07:15:51 Intraday data recording state for symbol YM.20140900.CME_E is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: NQ.20141200.CME_Eq. ID: 13 | 2015-06-18 07:15:51 Intraday data recording state for symbol NQ.20141200.CME_Eq is set to download pending. | 2015-06-18 07:15:51 CTS T4 FIX | Starting real-time market data updates for: NQ.20140900.CME_Eq. ID: 14 | 2015-06-18 07:15:51 Intraday data recording state for symbol NQ.20140900.CME_Eq is set to download pending. | 2015-06-18 07:15:51 HD Request # 8 | Downloading Intraday chart data for CL.20141000.CME_NY to the file CL.20141000.CME_NY.scid. Service: nymex | 2015-06-18 07:15:51 HD Request # 8 | Download start Date-Time: 2014-09-22 13:29:55.0 | 2015-06-18 07:15:52 HD Request # 8 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:15:52 CTS FIX: Received Account List collateral report. | 2015-06-18 07:15:52 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:15:52 Socket (3) | Connected. | 2015-06-18 07:15:52 HD Request # 8 | Sending historical data logon request message. | 2015-06-18 07:15:52 CTS FIX: Subscribing to account: 7G* | 2015-06-18 07:15:52 Supported exchange: L_J (Euronext Paris Index Futures) | 2015-06-18 07:15:52 Supported exchange: CME_TR (CME TRAKRS Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_IC (ICE EU Futures) | 2015-06-18 07:15:52 Supported exchange: L_Y (Euronext Paris Commodity Futures) | 2015-06-18 07:15:52 Supported exchange: CME_ELE (NYMEX Power Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_WOp (ICE Canada Options) | 2015-06-18 07:15:52 Supported exchange: L_YOp (Euronext Paris Commodity Options) | 2015-06-18 07:15:52 Supported exchange: E_INXOp (Eurex Index Options) | 2015-06-18 07:15:52 Supported exchange: CME_KOp (KCBT Options) | 2015-06-18 07:15:52 Supported exchange: CME_HoOp (CME Housing Options) | 2015-06-18 07:15:52 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2015-06-18 07:15:52 Supported exchange: ICE_ICOp (ICE EU Options) | 2015-06-18 07:15:52 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2015-06-18 07:15:52 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2015-06-18 07:15:52 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2015-06-18 07:15:52 Supported exchange: CME_COp (CBOT Commodity Options) | 2015-06-18 07:15:52 Supported exchange: CME_EqOp (CME Equity Options) | 2015-06-18 07:15:52 Supported exchange: E_VOL (Eurex Volatility Futures) | 2015-06-18 07:15:52 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_IN (ICE US Index Futures) | 2015-06-18 07:15:52 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2015-06-18 07:15:52 Supported exchange: CME_Ho (CME Housing Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_INOp (ICE US Index Options) | 2015-06-18 07:15:52 Supported exchange: CME_AgOp (CME Agricultural Options) | 2015-06-18 07:15:52 Supported exchange: CME_In (CME Interest Rate Futures) | 2015-06-18 07:15:52 Supported exchange: E_CUR (Eurex Currency Futures) | 2015-06-18 07:15:52 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2015-06-18 07:15:52 Supported exchange: CME_CO (COMEX Futures) | 2015-06-18 07:15:52 Supported exchange: CME_Ag (CME Agricultural Futures) | 2015-06-18 07:15:52 Supported exchange: CME_EOp (CBOT Equity Options) | 2015-06-18 07:15:52 Supported exchange: CME_C (CBOT Commodity Futures) | 2015-06-18 07:15:52 Supported exchange: CME_F (CBOT Financial Futures) | 2015-06-18 07:15:52 Supported exchange: CME_E (CBOT Equity Futures) | 2015-06-18 07:15:52 Supported exchange: CME_K (KCBT Futures) | 2015-06-18 07:15:52 Supported exchange: CME_O (MGEX Futures) | 2015-06-18 07:15:52 Supported exchange: CME_FOp (CBOT Financial Options) | 2015-06-18 07:15:52 Supported exchange: ICE_MOp (ICE US Metals Options) | 2015-06-18 07:15:52 Supported exchange: E_INX (Eurex Index Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_M (ICE US Metals Futures) | 2015-06-18 07:15:52 Supported exchange: CME_OOp (MGEX Options) | 2015-06-18 07:15:52 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2015-06-18 07:15:52 Supported exchange: ICE_CU (ICE US Currency Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2015-06-18 07:15:52 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2015-06-18 07:15:52 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2015-06-18 07:15:52 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_F (ICE EU Financial Futures) | 2015-06-18 07:15:52 Supported exchange: CME_NYOp (NYMEX Options) | 2015-06-18 07:15:52 Supported exchange: CME_We (CME Weather Futures) | 2015-06-18 07:15:52 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2015-06-18 07:15:52 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_W (ICE Canada Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2015-06-18 07:15:52 Supported exchange: E_CUROp (Eurex Currency Options) | 2015-06-18 07:15:52 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2015-06-18 07:15:52 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2015-06-18 07:15:52 Supported exchange: CME_COOp (COMEX Options) | 2015-06-18 07:15:52 Supported exchange: LME_ME (LME Metal Futures) | 2015-06-18 07:15:52 Supported exchange: LME_PL (LME Plastic Futures) | 2015-06-18 07:15:52 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2015-06-18 07:15:52 Supported exchange: CME_InOp (CME Interest Rate Options) | 2015-06-18 07:15:52 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2015-06-18 07:15:52 Supported exchange: CME_Eq (CME Equity Futures) | 2015-06-18 07:15:52 Supported exchange: CBOE_CFE (CFE) | 2015-06-18 07:15:52 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2015-06-18 07:15:52 Supported exchange: CME_NY (NYMEX Futures) | 2015-06-18 07:15:52 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2015-06-18 07:15:52 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2015-06-18 07:15:52 Supported exchange: LME_IN (LME Index Futures) | 2015-06-18 07:15:52 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-09-22 13:29:55. Record interval: 1. Symbol: CLV14 | 2015-06-18 07:15:52 HD Request # 8 | Decompressing data. | 2015-06-18 07:15:52 HD Request # 8 | Receiving Intraday data for CL.20141000.CME_NY starting at 2014-09-22 13:29:55 | 2015-06-18 07:15:52 HD Request # 8 | Timestamp of first Intraday data file record written: 2014-09-22 13:29:55 | 2015-06-18 07:15:52 Socket (3) | Shutdown and closed. | 2015-06-18 07:15:52 The network socket for historical data has been closed. | 2015-06-18 07:15:52 CTS T4 FIX | Starting real-time market data updates for: ES.20150900.CME_Eq. ID: 15 | 2015-06-18 07:15:52 Intraday data recording state for symbol ES.20150900.CME_Eq is set to download pending. | 2015-06-18 07:15:52 HD Request # 8 | Received 1 record from 2014-09-22 13:29:55 to 2014-09-22 13:29:55 (0.0 seconds) and wrote 1 record for CL.20141000.CME_NY | 2015-06-18 07:15:52 HD Request # 8 | Intraday download COMPLETE for CL.20141000.CME_NY. Completion time: 1s. Unique request ID: 7 | 2015-06-18 07:15:52 Removed historical data download ID 7 | 2015-06-18 07:15:52 Real-time Intraday chart data file updates started for CL.20141000.CME_NY | 2015-06-18 07:15:52 HD Request # 9 | Downloading Intraday chart data for ES.20150900.CME_Eq to the file ES.20150900.CME_Eq.scid. Service: cts | 2015-06-18 07:15:52 HD Request # 9 | Download start Date-Time: 2015-06-17 22:10:37.0 | 2015-06-18 07:15:53 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2015-06-18 07:15:53 HD Request # 10 | Downloading Intraday chart data for NG.20141000.CME_NY to the file NG.20141000.CME_NY.scid. Service: nymex | 2015-06-18 07:15:53 HD Request # 10 | Download start Date-Time: 2014-09-26 13:29:58.0 | 2015-06-18 07:15:53 HD Request # 10 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:15:53 CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 69.44.110.227 | 2015-06-18 07:15:53 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:15:53 Socket (5) | Connected. | 2015-06-18 07:15:53 HD Request # 10 | Sending historical data logon request message. | 2015-06-18 07:15:53 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2014-09-26 13:29:58. Record interval: 1. Symbol: NGV14 | 2015-06-18 07:15:53 CTS T4 FIX | Starting real-time market data updates for: CL.20150700.CME_NY. ID: 16 | 2015-06-18 07:15:53 Intraday data recording state for symbol CL.20150700.CME_NY is set to download pending. | 2015-06-18 07:15:53 CTS FIX Historical Data socket (4) | Connected. | 2015-06-18 07:15:53 CTS FIX Historical Data socket (4) | Starting SSL connection. | 2015-06-18 07:15:53 CTS T4 FIX | Starting real-time market data updates for: YM.20150900.CME_E. ID: 17 | 2015-06-18 07:15:53 Intraday data recording state for symbol YM.20150900.CME_E is set to download pending. | 2015-06-18 07:15:54 CTS T4 FIX | Starting real-time market data updates for: ZB.20150900.CME_F. ID: 18 | 2015-06-18 07:15:54 Intraday data recording state for symbol ZB.20150900.CME_F is set to download pending. | 2015-06-18 07:15:54 CTS T4 FIX | Starting real-time market data updates for: TF.20150900.ICE_IN. ID: 19 | 2015-06-18 07:15:54 CTS T4 FIX | Starting real-time market data updates for: 6E.20150900.CME_Fo. ID: 20 | 2015-06-18 07:15:54 HD Request # 10 | Decompressing data. | 2015-06-18 07:15:54 HD Request # 10 | Receiving Intraday data for NG.20141000.CME_NY starting at 2014-09-26 13:29:58 | 2015-06-18 07:15:54 Socket (5) | Shutdown and closed. | 2015-06-18 07:15:54 The network socket for historical data has been closed. | 2015-06-18 07:15:54 CTS FIX Historical Data socket (4) | SSL connection established. | 2015-06-18 07:15:54 HD Request # 10 | Received 1 record from 2014-09-26 13:29:58 to 2014-09-26 13:29:58 (0.0 seconds) and wrote 0 records for NG.20141000.CME_NY | 2015-06-18 07:15:54 HD Request # 10 | Intraday download COMPLETE for NG.20141000.CME_NY. Completion time: 0s. Unique request ID: 8 | 2015-06-18 07:15:54 Removed historical data download ID 8 | 2015-06-18 07:15:54 Real-time Intraday chart data file updates started for NG.20141000.CME_NY | 2015-06-18 07:15:54 HD Request # 11 | Downloading Intraday chart data for ZS.20141100.CME_C to the file ZS.20141100.CME_C.scid. Service: cbot | 2015-06-18 07:15:54 HD Request # 11 | Download start Date-Time: 2014-11-14 11:43:56.0 | 2015-06-18 07:15:56 HD Request # 11 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:15:56 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:15:56 CTS FIX: Received Account Update collateral report. | 2015-06-18 07:15:56 Intraday data recording state for symbol 6E.20150900.CME_Fo is set to download pending. | 2015-06-18 07:15:56 Socket (6) | Connected. | 2015-06-18 07:15:56 HD Request # 11 | Sending historical data logon request message. | 2015-06-18 07:15:56 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2014-11-14 11:43:56. Record interval: 1. Symbol: ZSX14 | 2015-06-18 07:15:56 HD Request # 11 | Decompressing data. | 2015-06-18 07:15:56 HD Request # 11 | Receiving Intraday data for ZS.20141100.CME_C starting at 2014-11-14 11:43:56 | 2015-06-18 07:15:56 Socket (6) | Shutdown and closed. | 2015-06-18 07:15:56 The network socket for historical data has been closed. | 2015-06-18 07:15:56 HD Request # 11 | Received 1 record from 2014-11-14 11:43:56 to 2014-11-14 11:43:56 (0.0 seconds) and wrote 0 records for ZS.20141100.CME_C | 2015-06-18 07:15:56 HD Request # 11 | Intraday download COMPLETE for ZS.20141100.CME_C. Completion time: 2s. Unique request ID: 9 | 2015-06-18 07:15:56 Removed historical data download ID 9 | 2015-06-18 07:15:56 Real-time Intraday chart data file updates started for ZS.20141100.CME_C | 2015-06-18 07:15:56 HD Request # 12 | Downloading Intraday chart data for GC.20141200.CME_CO to the file GC.20141200.CME_CO.scid. Service: comex | 2015-06-18 07:15:56 HD Request # 12 | Download start Date-Time: 2014-12-29 10:02:27.0 | 2015-06-18 07:15:58 HD Request # 12 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:15:58 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:15:58 Intraday data recording state for symbol TF.20150900.ICE_IN is set to download pending. | 2015-06-18 07:15:58 Socket (7) | Connected. | 2015-06-18 07:15:58 HD Request # 12 | Sending historical data logon request message. | 2015-06-18 07:15:58 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2014-12-29 10:02:27. Record interval: 1. Symbol: GCZ14 | 2015-06-18 07:15:58 HD Request # 12 | Decompressing data. | 2015-06-18 07:15:58 HD Request # 12 | Receiving Intraday data for GC.20141200.CME_CO starting at 2014-12-29 10:02:27 | 2015-06-18 07:15:58 HD Request # 12 | Timestamp of first Intraday data file record written: 2014-12-29 10:02:27 | 2015-06-18 07:15:58 Socket (7) | Shutdown and closed. | 2015-06-18 07:15:58 The network socket for historical data has been closed. | 2015-06-18 07:15:58 HD Request # 12 | Received 1 record from 2014-12-29 10:02:27 to 2014-12-29 10:02:27 (0.0 seconds) and wrote 1 record for GC.20141200.CME_CO | 2015-06-18 07:15:58 HD Request # 12 | Intraday download COMPLETE for GC.20141200.CME_CO. Completion time: 2s. Unique request ID: 10 | 2015-06-18 07:15:58 Removed historical data download ID 10 | 2015-06-18 07:15:58 Real-time Intraday chart data file updates started for GC.20141200.CME_CO | 2015-06-18 07:15:58 HD Request # 13 | Downloading Intraday chart data for ZB.20140900.CME_F to the file ZB.20140900.CME_F.scid. Service: cbot | 2015-06-18 07:15:58 HD Request # 13 | Download start Date-Time: 2014-09-19 11:49:53.0 | 2015-06-18 07:16:00 HD Request # 13 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:16:00 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:16:00 Socket (8) | Connected. | 2015-06-18 07:16:00 HD Request # 13 | Sending historical data logon request message. | 2015-06-18 07:16:00 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2014-09-19 11:49:53. Record interval: 1. Symbol: ZBU14 | 2015-06-18 07:16:00 HD Request # 13 | Decompressing data. | 2015-06-18 07:16:00 HD Request # 13 | Receiving Intraday data for ZB.20140900.CME_F starting at 2014-09-19 11:49:53 | 2015-06-18 07:16:00 Socket (8) | Shutdown and closed. | 2015-06-18 07:16:00 The network socket for historical data has been closed. | 2015-06-18 07:16:00 HD Request # 13 | Received 1 record from 2014-09-19 11:49:53 to 2014-09-19 11:49:53 (0.0 seconds) and wrote 0 records for ZB.20140900.CME_F | 2015-06-18 07:16:00 HD Request # 13 | Intraday download COMPLETE for ZB.20140900.CME_F. Completion time: 2s. Unique request ID: 11 | 2015-06-18 07:16:00 Removed historical data download ID 11 | 2015-06-18 07:16:00 Real-time Intraday chart data file updates started for ZB.20140900.CME_F | 2015-06-18 07:16:00 HD Request # 14 | Downloading Intraday chart data for ZB.20141200.CME_F to the file ZB.20141200.CME_F.scid. Service: cbot | 2015-06-18 07:16:00 HD Request # 14 | Download start Date-Time: 2014-12-19 11:03:21.0 | 2015-06-18 07:16:02 HD Request # 14 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:16:02 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:16:02 Socket (9) | Connected. | 2015-06-18 07:16:02 HD Request # 14 | Sending historical data logon request message. | 2015-06-18 07:16:02 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2014-12-19 11:03:21. Record interval: 1. Symbol: ZBZ14 | 2015-06-18 07:16:02 HD Request # 14 | Decompressing data. | 2015-06-18 07:16:02 HD Request # 14 | Receiving Intraday data for ZB.20141200.CME_F starting at 2014-12-19 11:03:21 | 2015-06-18 07:16:02 HD Request # 14 | Timestamp of first Intraday data file record written: 2014-12-19 11:03:21 | 2015-06-18 07:16:02 Socket (9) | Shutdown and closed. | 2015-06-18 07:16:02 The network socket for historical data has been closed. | 2015-06-18 07:16:02 HD Request # 14 | Received 1 record from 2014-12-19 11:03:21 to 2014-12-19 11:03:21 (0.0 seconds) and wrote 1 record for ZB.20141200.CME_F | 2015-06-18 07:16:02 HD Request # 14 | Intraday download COMPLETE for ZB.20141200.CME_F. Completion time: 2s. Unique request ID: 12 | 2015-06-18 07:16:02 Removed historical data download ID 12 | 2015-06-18 07:16:02 Real-time Intraday chart data file updates started for ZB.20141200.CME_F | 2015-06-18 07:16:02 HD Request # 15 | Downloading Intraday chart data for ES.20141200.CME_Eq to the file ES.20141200.CME_Eq.scid. Service: cme | 2015-06-18 07:16:02 HD Request # 15 | Download start Date-Time: 2014-12-19 08:29:59.0 | 2015-06-18 07:16:06 HD Request # 15 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:16:06 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:16:06 Socket (10) | Connected. | 2015-06-18 07:16:06 HD Request # 15 | Sending historical data logon request message. | 2015-06-18 07:16:06 CTS T4 FIX | Sending security definition request for symbol 6E.20150900.CME_Fo | 2015-06-18 07:16:06 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2014-12-19 08:29:59. Record interval: 1. Symbol: ESZ14 | 2015-06-18 07:16:06 CTS T4 FIX | Received matching security definition for symbol 6E.20150900.CME_Fo. Subscribing to data. | 2015-06-18 07:16:06 CTS T4 FIX | Received 1 security definitions for underlying symbol 6E | 2015-06-18 07:16:06 HD Request # 15 | Decompressing data. | 2015-06-18 07:16:06 HD Request # 15 | Receiving Intraday data for ES.20141200.CME_Eq starting at 2014-12-19 08:29:59 | 2015-06-18 07:16:06 HD Request # 15 | Timestamp of first Intraday data file record written: 2014-12-19 08:29:59 | 2015-06-18 07:16:06 Socket (10) | Shutdown and closed. | 2015-06-18 07:16:06 The network socket for historical data has been closed. | 2015-06-18 07:16:06 CTS FIX Historical Data: Sending the Logon message. | 2015-06-18 07:16:06 CTS FIX: Requesting Open Orders for account: 7G* | 2015-06-18 07:16:06 HD Request # 15 | Received 1 record from 2014-12-19 08:29:59 to 2014-12-19 08:29:59 (0.0 seconds) and wrote 1 record for ES.20141200.CME_Eq | 2015-06-18 07:16:06 HD Request # 15 | Intraday download COMPLETE for ES.20141200.CME_Eq. Completion time: 4s. Unique request ID: 13 | 2015-06-18 07:16:06 Removed historical data download ID 13 | 2015-06-18 07:16:06 Real-time Intraday chart data file updates started for ES.20141200.CME_Eq | 2015-06-18 07:16:06 CTS FIX Historical Data: Connected to Historical data server. | 2015-06-18 07:16:06 HD Request # 16 | Downloading Intraday chart data for ES.20140900.CME_Eq to the file ES.20140900.CME_Eq.scid. Service: cme | 2015-06-18 07:16:06 HD Request # 16 | Download start Date-Time: 2014-09-19 08:29:59.0 | 2015-06-18 07:16:09 HD Request # 16 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:16:09 CTS FIX: Received Account List collateral report. | 2015-06-18 07:16:09 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:16:09 CTS FIX: Received Account List collateral report. | 2015-06-18 07:16:09 CTS T4 FIX | Sending security definition request for symbol CL.20141000.CME_NY | 2015-06-18 07:16:09 Socket (11) | Connected. | 2015-06-18 07:16:09 HD Request # 16 | Sending historical data logon request message. | 2015-06-18 07:16:09 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2014-09-19 08:29:59. Record interval: 1. Symbol: ESU14 | 2015-06-18 07:16:09 Symbol Error - CL.20141000.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:09 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2015-06-18 07:16:09 HD Request # 16 | Decompressing data. | 2015-06-18 07:16:09 HD Request # 16 | Receiving Intraday data for ES.20140900.CME_Eq starting at 2014-09-19 08:29:59 | 2015-06-18 07:16:09 HD Request # 16 | Timestamp of first Intraday data file record written: 2014-09-19 08:29:59 | 2015-06-18 07:16:09 Socket (11) | Shutdown and closed. | 2015-06-18 07:16:09 The network socket for historical data has been closed. | 2015-06-18 07:16:09 HD Request # 16 | Received 1 record from 2014-09-19 08:29:59 to 2014-09-19 08:29:59 (0.0 seconds) and wrote 1 record for ES.20140900.CME_Eq | 2015-06-18 07:16:09 HD Request # 16 | Intraday download COMPLETE for ES.20140900.CME_Eq. Completion time: 3s. Unique request ID: 14 | 2015-06-18 07:16:09 Removed historical data download ID 14 | 2015-06-18 07:16:09 Real-time Intraday chart data file updates started for ES.20140900.CME_Eq | 2015-06-18 07:16:09 HD Request # 17 | Downloading Intraday chart data for TF.20141200.ICE_IN to the file TF.20141200.ICE_IN.scid. Service: ice.us | 2015-06-18 07:16:09 HD Request # 17 | Download start Date-Time: 2014-12-19 08:28:24.0 | 2015-06-18 07:16:11 HD Request # 17 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:16:11 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:16:11 Socket (12) | Connected. | 2015-06-18 07:16:11 HD Request # 17 | Sending historical data logon request message. | 2015-06-18 07:16:11 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2014-12-19 08:28:24. Record interval: 1. Symbol: RJZ14 | 2015-06-18 07:16:11 HD Request # 17 | Decompressing data. | 2015-06-18 07:16:11 HD Request # 17 | Receiving Intraday data for TF.20141200.ICE_IN starting at 2014-12-19 08:28:24 | 2015-06-18 07:16:11 HD Request # 17 | Timestamp of first Intraday data file record written: 2014-12-19 08:28:24 | 2015-06-18 07:16:11 Socket (12) | Shutdown and closed. | 2015-06-18 07:16:11 The network socket for historical data has been closed. | 2015-06-18 07:16:11 HD Request # 17 | Received 1 record from 2014-12-19 08:28:24 to 2014-12-19 08:28:24 (0.0 seconds) and wrote 1 record for TF.20141200.ICE_IN | 2015-06-18 07:16:11 HD Request # 17 | Intraday download COMPLETE for TF.20141200.ICE_IN. Completion time: 2s. Unique request ID: 15 | 2015-06-18 07:16:11 Removed historical data download ID 15 | 2015-06-18 07:16:11 Real-time Intraday chart data file updates started for TF.20141200.ICE_IN | 2015-06-18 07:16:11 HD Request # 18 | Downloading Intraday chart data for TF.20140900.ICE_IN to the file TF.20140900.ICE_IN.scid. Service: ice.us | 2015-06-18 07:16:11 HD Request # 18 | Download start Date-Time: 2014-09-19 08:27:40.0 | 2015-06-18 07:16:12 HD Request # 18 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:16:12 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:16:12 Socket (13) | Connected. | 2015-06-18 07:16:12 HD Request # 18 | Sending historical data logon request message. | 2015-06-18 07:16:12 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2014-09-19 08:27:40. Record interval: 1. Symbol: RJU14 | 2015-06-18 07:16:12 CTS T4 FIX | Sending security definition request for symbol CL.20150700.CME_NY | 2015-06-18 07:16:12 HD Request # 18 | Decompressing data. | 2015-06-18 07:16:12 HD Request # 18 | Receiving Intraday data for TF.20140900.ICE_IN starting at 2014-09-19 08:27:40 | 2015-06-18 07:16:12 HD Request # 18 | Timestamp of first Intraday data file record written: 2014-09-19 08:27:40 | 2015-06-18 07:16:12 Socket (13) | Shutdown and closed. | 2015-06-18 07:16:12 The network socket for historical data has been closed. | 2015-06-18 07:16:12 HD Request # 18 | Received 1 record from 2014-09-19 08:27:40 to 2014-09-19 08:27:40 (0.0 seconds) and wrote 1 record for TF.20140900.ICE_IN | 2015-06-18 07:16:12 HD Request # 18 | Intraday download COMPLETE for TF.20140900.ICE_IN. Completion time: 1s. Unique request ID: 16 | 2015-06-18 07:16:12 Removed historical data download ID 16 | 2015-06-18 07:16:12 Real-time Intraday chart data file updates started for TF.20140900.ICE_IN | 2015-06-18 07:16:12 CTS T4 FIX | Received matching security definition for symbol CL.20150700.CME_NY. Subscribing to data. | 2015-06-18 07:16:12 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2015-06-18 07:16:12 HD Request # 19 | Downloading Intraday chart data for YM.20141200.CME_E to the file YM.20141200.CME_E.scid. Service: cbot | 2015-06-18 07:16:12 HD Request # 19 | Download start Date-Time: 2014-12-19 08:29:57.0 | 2015-06-18 07:16:13 HD Request # 19 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:16:13 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:16:13 Socket (14) | Connected. | 2015-06-18 07:16:13 HD Request # 19 | Sending historical data logon request message. | 2015-06-18 07:16:13 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2014-12-19 08:29:57. Record interval: 1. Symbol: YMZ14 | 2015-06-18 07:16:13 HD Request # 19 | Decompressing data. | 2015-06-18 07:16:13 HD Request # 19 | Receiving Intraday data for YM.20141200.CME_E starting at 2014-12-19 08:29:57 | 2015-06-18 07:16:13 HD Request # 19 | Timestamp of first Intraday data file record written: 2014-12-19 08:29:57 | 2015-06-18 07:16:13 Socket (14) | Shutdown and closed. | 2015-06-18 07:16:13 The network socket for historical data has been closed. | 2015-06-18 07:16:13 HD Request # 19 | Received 1 record from 2014-12-19 08:29:57 to 2014-12-19 08:29:57 (0.0 seconds) and wrote 1 record for YM.20141200.CME_E | 2015-06-18 07:16:13 HD Request # 19 | Intraday download COMPLETE for YM.20141200.CME_E. Completion time: 2s. Unique request ID: 17 | 2015-06-18 07:16:14 Removed historical data download ID 17 | 2015-06-18 07:16:14 Real-time Intraday chart data file updates started for YM.20141200.CME_E | 2015-06-18 07:16:14 HD Request # 20 | Downloading Intraday chart data for YM.20140900.CME_E to the file YM.20140900.CME_E.scid. Service: cbot | 2015-06-18 07:16:14 HD Request # 20 | Download start Date-Time: 2014-09-19 08:29:51.0 | 2015-06-18 07:16:14 HD Request # 20 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:16:14 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:16:14 Socket (15) | Connected. | 2015-06-18 07:16:14 HD Request # 20 | Sending historical data logon request message. | 2015-06-18 07:16:14 CTS T4 FIX | Sending security definition request for symbol ES.20140900.CME_Eq | 2015-06-18 07:16:14 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2014-09-19 08:29:51. Record interval: 1. Symbol: YMU14 | 2015-06-18 07:16:14 Symbol Error - ES.20140900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:14 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-06-18 07:16:14 HD Request # 20 | Decompressing data. | 2015-06-18 07:16:15 HD Request # 20 | Receiving Intraday data for YM.20140900.CME_E starting at 2014-09-19 08:29:51 | 2015-06-18 07:16:15 HD Request # 20 | Timestamp of first Intraday data file record written: 2014-09-19 08:29:51 | 2015-06-18 07:16:15 Socket (15) | Shutdown and closed. | 2015-06-18 07:16:15 The network socket for historical data has been closed. | 2015-06-18 07:16:15 HD Request # 20 | Received 1 record from 2014-09-19 08:29:51 to 2014-09-19 08:29:51 (0.0 seconds) and wrote 1 record for YM.20140900.CME_E | 2015-06-18 07:16:15 HD Request # 20 | Intraday download COMPLETE for YM.20140900.CME_E. Completion time: 0s. Unique request ID: 18 | 2015-06-18 07:16:15 Removed historical data download ID 18 | 2015-06-18 07:16:15 Real-time Intraday chart data file updates started for YM.20140900.CME_E | 2015-06-18 07:16:15 HD Request # 21 | Downloading Intraday chart data for NQ.20141200.CME_Eq to the file NQ.20141200.CME_Eq.scid. Service: cme | 2015-06-18 07:16:15 HD Request # 21 | Download start Date-Time: 2014-12-19 08:29:53.0 | 2015-06-18 07:16:17 HD Request # 21 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 07:16:17 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 07:16:17 Socket (16) | Connected. | 2015-06-18 07:16:17 HD Request # 21 | Sending historical data logon request message. | 2015-06-18 07:16:17 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2014-12-19 08:29:53. Record interval: 1. Symbol: NQZ14 | 2015-06-18 07:16:17 HD Request # 21 | Decompressing data. | 2015-06-18 07:16:17 HD Request # 21 | Receiving Intraday data for NQ.20141200.CME_Eq starting at 2014-12-19 08:29:53 | 2015-06-18 07:16:17 HD Request # 21 | Timestamp of first Intraday data file record written: 2014-12-19 08:29:53 | 2015-06-18 07:16:17 Socket (16) | Shutdown and closed. | 2015-06-18 07:16:17 The network socket for historical data has been closed. | 2015-06-18 07:16:17 HD Request # 21 | Received 1 record from 2014-12-19 08:29:53 to 2014-12-19 08:29:53 (0.0 seconds) and wrote 1 record for NQ.20141200.CME_Eq | 2015-06-18 07:16:17 HD Request # 21 | Intraday download COMPLETE for NQ.20141200.CME_Eq. Completion time: 2s. Unique request ID: 19 | 2015-06-18 07:16:17 Removed historical data download ID 19 | 2015-06-18 07:16:17 Real-time Intraday chart data file updates started for NQ.20141200.CME_Eq | 2015-06-18 07:16:17 HD Request # 22 | Downloading Intraday chart data for NQ.20140900.CME_Eq to the file NQ.20140900.CME_Eq.scid. Service: cme | 2015-06-18 07:16:17 HD Request # 22 | Download start Date-Time: 2014-09-19 08:29:59.0 | 2015-06-18 07:16:17 HD Request # 22 | Using server: scdf2.sierracharts.com port 10149 | 2015-06-18 07:16:17 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-06-18 07:16:17 Socket (17) | Connected. | 2015-06-18 07:16:17 HD Request # 22 | Sending historical data logon request message. | 2015-06-18 07:16:17 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2014-09-19 08:29:59. Record interval: 1. Symbol: NQU14 | 2015-06-18 07:16:17 HD Request # 22 | Decompressing data. | 2015-06-18 07:16:18 HD Request # 22 | Receiving Intraday data for NQ.20140900.CME_Eq starting at 2014-09-19 08:29:59 | 2015-06-18 07:16:18 Socket (17) | Shutdown and closed. | 2015-06-18 07:16:18 The network socket for historical data has been closed. | 2015-06-18 07:16:18 HD Request # 22 | Received 1 record from 2014-09-19 08:29:59 to 2014-09-19 08:29:59 (0.0 seconds) and wrote 0 records for NQ.20140900.CME_Eq | 2015-06-18 07:16:18 HD Request # 22 | Intraday download COMPLETE for NQ.20140900.CME_Eq. Completion time: 0s. Unique request ID: 20 | 2015-06-18 07:16:18 Removed historical data download ID 20 | 2015-06-18 07:16:18 Real-time Intraday chart data file updates started for NQ.20140900.CME_Eq | 2015-06-18 07:16:18 CTS T4 FIX | Sending security definition request for symbol ES.20141200.CME_Eq | 2015-06-18 07:16:18 Symbol Error - ES.20141200.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:18 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-06-18 07:16:18 CTS T4 FIX | Sending security definition request for symbol ES.20150900.CME_Eq | 2015-06-18 07:16:18 CTS T4 FIX | Received matching security definition for symbol ES.20150900.CME_Eq. Subscribing to data. | 2015-06-18 07:16:18 CTS T4 FIX | Received matching security definition for symbol ES.20150900.CME_Eq. Requesting historical data. | 2015-06-18 07:16:18 HD Request # 9 | Requesting historical Tick data for ES.20150900.CME_Eq from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 07:16:18 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2015-06-18 07:16:18 CTS T4 FIX | Sending security definition request for symbol GC.20141200.CME_CO | 2015-06-18 07:16:20 Symbol Error - GC.20141200.CME_CO is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:20 CTS T4 FIX | Received 0 security definitions for underlying symbol GC | 2015-06-18 07:16:20 CTS T4 FIX | Sending security definition request for symbol NG.20141000.CME_NY | 2015-06-18 07:16:21 Symbol Error - NG.20141000.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:21 CTS T4 FIX | Received 0 security definitions for underlying symbol NG | 2015-06-18 07:16:21 HD Request # 9 | Receiving Intraday data for ES.20150900.CME_Eq starting at 2015-06-16 17:00:00 | 2015-06-18 07:16:23 HD Request # 9 | Total records received: 422839 | 2015-06-18 07:16:25 HD Request # 9 | Requesting historical Tick data for ES.20150900.CME_Eq from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 07:16:25 CTS T4 FIX | Sending security definition request for symbol NQ.20140900.CME_Eq | 2015-06-18 07:16:25 Symbol Error - NQ.20140900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:25 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2015-06-18 07:16:25 HD Request # 9 | Timestamp of first Intraday data file record written: 2015-06-17 22:11:59 | 2015-06-18 07:16:26 HD Request # 9 | Total records received: 496678 | 2015-06-18 07:16:26 HD Request # 9 | Requesting historical Tick data for ES.20150900.CME_Eq from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 07:16:26 HD Request # 9 | Total records received: 496678 | 2015-06-18 07:16:26 HD Request # 9 | Requesting historical Tick data for ES.20150900.CME_Eq from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 07:16:26 CTS T4 FIX | Sending security definition request for symbol NQ.20141200.CME_Eq | 2015-06-18 07:16:26 HD Request # 9 | Received 496678 records from 2015-06-16 17:00:00 to 2015-06-18 07:16:22 (38.3 hours) and wrote 65554 records for ES.20150900.CME_Eq | 2015-06-18 07:16:26 HD Request # 9 | Intraday download COMPLETE for ES.20150900.CME_Eq. Completion time: 34s. Unique request ID: 21 | 2015-06-18 07:16:26 Removed historical data download ID 21 | 2015-06-18 07:16:26 Real-time Intraday chart data file updates started for ES.20150900.CME_Eq | 2015-06-18 07:16:26 HD Request # 23 | Downloading Intraday chart data for CL.20150700.CME_NY to the file CL.20150700.CME_NY.scid. Service: cts | 2015-06-18 07:16:26 HD Request # 23 | Download start Date-Time: 2015-06-17 22:10:06.0 | 2015-06-18 07:16:26 HD Request # 23 | Requesting historical Tick data for CL.20150700.CME_NY from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 07:16:26 Symbol Error - NQ.20141200.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:26 CTS T4 FIX | Received 0 security definitions for underlying symbol NQ | 2015-06-18 07:16:26 CTS T4 FIX | Sending security definition request for symbol TF.20140900.ICE_IN | 2015-06-18 07:16:27 Symbol Error - TF.20140900.ICE_IN is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:28 CTS T4 FIX | Received 0 security definitions for underlying symbol TF | 2015-06-18 07:16:28 CTS T4 FIX | Sending security definition request for symbol TF.20141200.ICE_IN | 2015-06-18 07:16:29 Symbol Error - TF.20141200.ICE_IN is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:29 CTS T4 FIX | Received 0 security definitions for underlying symbol TF | 2015-06-18 07:16:29 HD Request # 23 | Receiving Intraday data for CL.20150700.CME_NY starting at 2015-06-16 17:00:00 | 2015-06-18 07:16:29 HD Request # 23 | Total records received: 211874 | 2015-06-18 07:16:30 HD Request # 23 | Requesting historical Tick data for CL.20150700.CME_NY from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 07:16:30 CTS T4 FIX | Sending security definition request for symbol TF.20150900.ICE_IN | 2015-06-18 07:16:30 CTS T4 FIX | Received matching security definition for symbol TF.20150900.ICE_IN. Subscribing to data. | 2015-06-18 07:16:31 CTS T4 FIX | Received 1 security definitions for underlying symbol TF | 2015-06-18 07:16:31 HD Request # 23 | Timestamp of first Intraday data file record written: 2015-06-17 22:11:38 | 2015-06-18 07:16:31 HD Request # 23 | Total records received: 239381 | 2015-06-18 07:16:31 HD Request # 23 | Requesting historical Tick data for CL.20150700.CME_NY from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 07:16:31 HD Request # 23 | Total records received: 239381 | 2015-06-18 07:16:31 HD Request # 23 | Requesting historical Tick data for CL.20150700.CME_NY from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 07:16:31 HD Request # 23 | Received 239381 records from 2015-06-16 17:00:00 to 2015-06-18 07:16:29 (38.3 hours) and wrote 24771 records for CL.20150700.CME_NY | 2015-06-18 07:16:31 HD Request # 23 | Intraday download COMPLETE for CL.20150700.CME_NY. Completion time: 5s. Unique request ID: 22 | 2015-06-18 07:16:31 Removed historical data download ID 22 | 2015-06-18 07:16:31 Real-time Intraday chart data file updates started for CL.20150700.CME_NY | 2015-06-18 07:16:31 HD Request # 24 | Downloading Intraday chart data for YM.20150900.CME_E to the file YM.20150900.CME_E.scid. Service: cts | 2015-06-18 07:16:31 HD Request # 24 | Download start Date-Time: 2015-06-17 22:10:16.0 | 2015-06-18 07:16:31 CTS T4 FIX | Sending security definition request for symbol YM.20140900.CME_E | 2015-06-18 07:16:32 Symbol Error - YM.20140900.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:32 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2015-06-18 07:16:32 CTS T4 FIX | Sending security definition request for symbol YM.20141200.CME_E | 2015-06-18 07:16:34 Symbol Error - YM.20141200.CME_E is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:34 CTS T4 FIX | Received 0 security definitions for underlying symbol YM | 2015-06-18 07:16:34 CTS T4 FIX | Sending security definition request for symbol YM.20150900.CME_E | 2015-06-18 07:16:35 CTS T4 FIX | Received matching security definition for symbol YM.20150900.CME_E. Subscribing to data. | 2015-06-18 07:16:35 CTS T4 FIX | Received matching security definition for symbol YM.20150900.CME_E. Requesting historical data. | 2015-06-18 07:16:35 HD Request # 24 | Requesting historical Tick data for YM.20150900.CME_E from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 07:16:35 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2015-06-18 07:16:35 HD Request # 24 | Receiving Intraday data for YM.20150900.CME_E starting at 2015-06-16 17:00:00 | 2015-06-18 07:16:36 HD Request # 24 | Total records received: 91039 | 2015-06-18 07:16:37 HD Request # 24 | Requesting historical Tick data for YM.20150900.CME_E from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 07:16:37 CTS T4 FIX | Sending security definition request for symbol ZB.20140900.CME_F | 2015-06-18 07:16:37 Symbol Error - ZB.20140900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:37 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2015-06-18 07:16:37 HD Request # 24 | Timestamp of first Intraday data file record written: 2015-06-17 22:11:50 | 2015-06-18 07:16:37 HD Request # 24 | Total records received: 107570 | 2015-06-18 07:16:37 HD Request # 24 | Requesting historical Tick data for YM.20150900.CME_E from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 07:16:37 HD Request # 24 | Total records received: 107570 | 2015-06-18 07:16:37 HD Request # 24 | Requesting historical Tick data for YM.20150900.CME_E from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 07:16:37 HD Request # 24 | Received 107570 records from 2015-06-16 17:00:00 to 2015-06-18 07:16:32 (38.3 hours) and wrote 14566 records for YM.20150900.CME_E | 2015-06-18 07:16:37 HD Request # 24 | Intraday download COMPLETE for YM.20150900.CME_E. Completion time: 6s. Unique request ID: 23 | 2015-06-18 07:16:37 Removed historical data download ID 23 | 2015-06-18 07:16:37 Real-time Intraday chart data file updates started for YM.20150900.CME_E | 2015-06-18 07:16:37 HD Request # 25 | Downloading Intraday chart data for ZB.20150900.CME_F to the file ZB.20150900.CME_F.scid. Service: cts | 2015-06-18 07:16:37 HD Request # 25 | Download start Date-Time: 2015-06-17 22:07:13.0 | 2015-06-18 07:16:37 CTS T4 FIX | Sending security definition request for symbol ZB.20141200.CME_F | 2015-06-18 07:16:38 Symbol Error - ZB.20141200.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:38 CTS T4 FIX | Received 0 security definitions for underlying symbol ZB | 2015-06-18 07:16:38 CTS T4 FIX | Sending security definition request for symbol ZB.20150900.CME_F | 2015-06-18 07:16:40 CTS T4 FIX | Received matching security definition for symbol ZB.20150900.CME_F. Subscribing to data. | 2015-06-18 07:16:40 CTS T4 FIX | Received matching security definition for symbol ZB.20150900.CME_F. Requesting historical data. | 2015-06-18 07:16:40 HD Request # 25 | Requesting historical Tick data for ZB.20150900.CME_F from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 07:16:40 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2015-06-18 07:16:40 HD Request # 25 | Receiving Intraday data for ZB.20150900.CME_F starting at 2015-06-16 17:00:00 | 2015-06-18 07:16:41 HD Request # 25 | Total records received: 41559 | 2015-06-18 07:16:41 HD Request # 25 | Requesting historical Tick data for ZB.20150900.CME_F from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 07:16:41 HD Request # 25 | Timestamp of first Intraday data file record written: 2015-06-17 22:10:56 | 2015-06-18 07:16:41 HD Request # 25 | Total records received: 53609 | 2015-06-18 07:16:41 HD Request # 25 | Requesting historical Tick data for ZB.20150900.CME_F from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 07:16:41 CTS T4 FIX | Sending security definition request for symbol ZS.20141100.CME_C | 2015-06-18 07:16:41 HD Request # 25 | Total records received: 53609 | 2015-06-18 07:16:41 HD Request # 25 | Requesting historical Tick data for ZB.20150900.CME_F from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 07:16:41 Symbol Error - ZS.20141100.CME_C is unknown, unavailable, or improperly formatted. Security definition not found | 2015-06-18 07:16:41 CTS T4 FIX | Received 0 security definitions for underlying symbol ZS | 2015-06-18 07:16:41 HD Request # 25 | Received 53609 records from 2015-06-16 17:00:00 to 2015-06-18 07:16:40 (38.3 hours) and wrote 10070 records for ZB.20150900.CME_F | 2015-06-18 07:16:41 Added 6 Time and Sales records to Intraday data file for ZB.20150900.CME_F after download. | 2015-06-18 07:16:41 HD Request # 25 | Intraday download COMPLETE for ZB.20150900.CME_F. Completion time: 4s. Unique request ID: 24 | 2015-06-18 07:16:41 Removed historical data download ID 24 | 2015-06-18 07:16:41 Real-time Intraday chart data file updates started for ZB.20150900.CME_F | 2015-06-18 07:16:41 HD Request # 26 | Downloading Intraday chart data for 6E.20150900.CME_Fo to the file 6E.20150900.CME_Fo.scid. Service: cts | 2015-06-18 07:16:41 HD Request # 26 | Download start Date-Time: 2015-06-17 22:10:29.0 | 2015-06-18 07:16:41 HD Request # 26 | Requesting historical Tick data for 6E.20150900.CME_Fo from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 07:16:41 HD Request # 26 | Receiving Intraday data for 6E.20150900.CME_Fo starting at 2015-06-16 17:00:00 | 2015-06-18 07:16:43 HD Request # 26 | Total records received: 132044 | 2015-06-18 07:16:44 HD Request # 26 | Requesting historical Tick data for 6E.20150900.CME_Fo from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 07:16:44 HD Request # 26 | Timestamp of first Intraday data file record written: 2015-06-17 22:11:03 | 2015-06-18 07:16:45 HD Request # 26 | Total records received: 193525 | 2015-06-18 07:16:45 HD Request # 26 | Requesting historical Tick data for 6E.20150900.CME_Fo from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 07:16:45 HD Request # 26 | Total records received: 193525 | 2015-06-18 07:16:45 HD Request # 26 | Requesting historical Tick data for 6E.20150900.CME_Fo from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 07:16:45 HD Request # 26 | Received 193525 records from 2015-06-16 17:00:00 to 2015-06-18 07:16:43 (38.3 hours) and wrote 54146 records for 6E.20150900.CME_Fo | 2015-06-18 07:16:45 Added 2 Time and Sales records to Intraday data file for 6E.20150900.CME_Fo after download. | 2015-06-18 07:16:45 HD Request # 26 | Intraday download COMPLETE for 6E.20150900.CME_Fo. Completion time: 4s. Unique request ID: 25 | 2015-06-18 07:16:45 Removed historical data download ID 25 | 2015-06-18 07:16:45 Real-time Intraday chart data file updates started for 6E.20150900.CME_Fo | 2015-06-18 07:16:45 HD Request # 27 | Downloading Intraday chart data for TF.20150900.ICE_IN to the file TF.20150900.ICE_IN.scid. Service: cts | 2015-06-18 07:16:45 HD Request # 27 | Download start Date-Time: 2015-06-17 22:06:30.0 | 2015-06-18 07:16:45 HD Request # 27 | Requesting historical Tick data for TF.20150900.ICE_IN from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 07:16:45 HD Request # 27 | Receiving Intraday data for TF.20150900.ICE_IN starting at 2015-06-16 19:00:00 | 2015-06-18 07:16:46 HD Request # 27 | Total records received: 60754 | 2015-06-18 07:16:47 HD Request # 27 | Requesting historical Tick data for TF.20150900.ICE_IN from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 07:16:47 HD Request # 27 | Timestamp of first Intraday data file record written: 2015-06-17 22:15:18 | 2015-06-18 07:16:47 HD Request # 27 | Total records received: 64780 | 2015-06-18 07:16:47 HD Request # 27 | Requesting historical Tick data for TF.20150900.ICE_IN from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 07:16:47 HD Request # 27 | Total records received: 64780 | 2015-06-18 07:16:47 HD Request # 27 | Requesting historical Tick data for TF.20150900.ICE_IN from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 07:16:47 HD Request # 27 | Received 64780 records from 2015-06-16 19:00:00 to 2015-06-18 07:16:32 (36.3 hours) and wrote 3761 records for TF.20150900.ICE_IN | 2015-06-18 07:16:47 HD Request # 27 | Intraday download COMPLETE for TF.20150900.ICE_IN. Completion time: 2s. Unique request ID: 26 | 2015-06-18 07:16:47 Removed historical data download ID 26 | 2015-06-18 07:16:47 Real-time Intraday chart data file updates started for TF.20150900.ICE_IN | 2015-06-18 07:16:47 CTS FIX Historical Data socket (4) | Closed. No error. | 2015-06-18 07:17:47 CTS FIX Historical Data socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2015-06-18 07:17:47 CTS FIX Historical Data socket (4) | SSL has been shut down. | 2015-06-18 07:17:47 CTS FIX Historical Data socket (4) | SSL object has been freed. SSL state is now disconnected. | 2015-06-18 07:17:47 CTS FIX Historical Data socket (4) | Shutdown and closed. | 2015-06-18 07:17:47 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2015-06-18 07:17:47 CTS FIX Historical Data: Disconnected. | 2015-06-18 07:17:47 CTS T4 FIX | Starting real-time market data updates for: RJ#. ID: 45 | 2015-06-18 08:44:19 Symbol Error - RJ# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 08:44:19 HD Request # 28 | Downloading Historical Daily chart data for RJ#. Starting date: 2015-06-11. Service: cts | 2015-06-18 08:44:19 HD Request # 28 | Requesting historical Daily Continuous data for RJZ10 starting at 2015-06-10 | 2015-06-18 08:44:19 HD Request # 28 | Receiving historical Daily data for RJ# starting at 2015-06-10 | 2015-06-18 08:44:19 Writing historical Daily data for RJ# to the file RJ#.dly | 2015-06-18 08:44:19 HD Request # 28 | Received 7 records from 2015-06-10 00:00:00 to 2015-06-18 00:00:00 (9.0 days) and wrote 6 records for RJ# | 2015-06-18 08:44:19 HD Request # 28 | Daily download COMPLETE for RJ#. Completion time: 0s. Unique request ID: 27 | 2015-06-18 08:44:19 Removed historical data download ID 27 | 2015-06-18 08:44:19 CTS T4 FIX | Starting real-time market data updates for: ES#. ID: 46 | 2015-06-18 08:54:31 Symbol Error - ES# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 08:54:31 HD Request # 29 | Downloading Historical Daily chart data for ES#. Starting date: 2015-06-15. Service: cts | 2015-06-18 08:54:31 HD Request # 29 | Requesting historical Daily Continuous data for ESZ10 starting at 2015-06-14 | 2015-06-18 08:54:31 HD Request # 29 | Receiving historical Daily data for ES# starting at 2015-06-15 | 2015-06-18 08:54:32 Writing historical Daily data for ES# to the file ES#.dly | 2015-06-18 08:54:32 HD Request # 29 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 4 records for ES# | 2015-06-18 08:54:32 HD Request # 29 | Daily download COMPLETE for ES#. Completion time: 1s. Unique request ID: 28 | 2015-06-18 08:54:32 Removed historical data download ID 28 | 2015-06-18 08:54:32 CTS T4 FIX | Starting real-time market data updates for: YM#. ID: 47 | 2015-06-18 08:56:58 Symbol Error - YM# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 08:56:58 HD Request # 30 | Downloading Historical Daily chart data for YM#. Starting date: 2015-06-15. Service: cts | 2015-06-18 08:56:58 HD Request # 30 | Requesting historical Daily Continuous data for YMZ10 starting at 2015-06-14 | 2015-06-18 08:56:58 HD Request # 30 | Receiving historical Daily data for YM# starting at 2015-06-15 | 2015-06-18 08:56:58 Writing historical Daily data for YM# to the file YM#.dly | 2015-06-18 08:56:58 HD Request # 30 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 4 records for YM# | 2015-06-18 08:56:58 HD Request # 30 | Daily download COMPLETE for YM#. Completion time: 1s. Unique request ID: 29 | 2015-06-18 08:56:59 Removed historical data download ID 29 | 2015-06-18 08:56:59 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:14:54 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:16:19 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:19:00 CTS T4 FIX | Starting real-time market data updates for: CL#. ID: 48 | 2015-06-18 09:23:38 Symbol Error - CL# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 09:23:38 HD Request # 31 | Downloading Historical Daily chart data for CL#. Starting date: 2015-06-16. Service: cts | 2015-06-18 09:23:38 HD Request # 31 | Requesting historical Daily Continuous data for CLZ10 starting at 2015-06-15 | 2015-06-18 09:23:38 HD Request # 31 | Receiving historical Daily data for CL# starting at 2015-06-15 | 2015-06-18 09:23:38 Writing historical Daily data for CL# to the file CL#.dly | 2015-06-18 09:23:38 HD Request # 31 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 3 records for CL# | 2015-06-18 09:23:38 HD Request # 31 | Daily download COMPLETE for CL#. Completion time: 0s. Unique request ID: 30 | 2015-06-18 09:23:38 Removed historical data download ID 30 | 2015-06-18 09:23:38 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:30:13 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:32:02 CTS T4 FIX | Starting real-time market data updates for: ZB#. ID: 49 | 2015-06-18 09:35:43 Symbol Error - ZB# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 09:35:43 HD Request # 32 | Downloading Historical Daily chart data for ZB#. Starting date: 2015-06-16. Service: cts | 2015-06-18 09:35:43 HD Request # 32 | Requesting historical Daily Continuous data for ZBZ10 starting at 2015-06-15 | 2015-06-18 09:35:43 HD Request # 32 | Receiving historical Daily data for ZB# starting at 2015-06-15 | 2015-06-18 09:35:43 Writing historical Daily data for ZB# to the file ZB#.dly | 2015-06-18 09:35:43 HD Request # 32 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 3 records for ZB# | 2015-06-18 09:35:43 HD Request # 32 | Daily download COMPLETE for ZB#. Completion time: 0s. Unique request ID: 31 | 2015-06-18 09:35:43 Removed historical data download ID 31 | 2015-06-18 09:35:43 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:37:29 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6E#.dly | 2015-06-18 09:46:19 CTS T4 FIX | Starting real-time market data updates for: 6E#. ID: 50 | 2015-06-18 09:46:19 Symbol Error - 6E# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 09:46:19 HD Request # 33 | Downloading Historical Daily chart data for 6E#. Starting date: 1965-06-18. Service: cts | 2015-06-18 09:46:19 HD Request # 33 | Error downloading historical Daily data for 6E#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 09:46:19 * HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E# | 2015-06-18 09:46:19 HD Request # 33 | Daily download COMPLETE for 6E#. Completion time: 0s. Unique request ID: 32 | 2015-06-18 09:46:19 Removed historical data download ID 32 | 2015-06-18 09:46:20 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6E#.dly | 2015-06-18 09:46:20 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 09:46:50 CTS T4 FIX | Starting real-time market data updates for: E6#. ID: 51 | 2015-06-18 09:46:50 Symbol Error - E6# is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-06-18 09:46:50 HD Request # 34 | Downloading Historical Daily chart data for E6#. Starting date: 1965-06-18. Service: cts | 2015-06-18 09:46:50 HD Request # 34 | Error downloading historical Daily data for E6#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 09:46:50 * HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for E6# | 2015-06-18 09:46:50 HD Request # 34 | Daily download COMPLETE for E6#. Completion time: 0s. Unique request ID: 33 | 2015-06-18 09:46:50 Removed historical data download ID 33 | 2015-06-18 09:46:50 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 09:46:51 Date rule based rollover from 6E.20121200.CME_Fo to next contract occurs at 2012-12-17. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20141200.CME_Fo to next contract occurs at 2014-12-15. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20150300.CME_Fo to next contract occurs at 2015-03-16. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20150600.CME_Fo to next contract occurs at 2015-06-15. | 2015-06-18 09:49:14 Date rule based rollover from 6E.20150900.CME_Fo to next contract occurs at 2015-09-14. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-17. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-18. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-17. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-16. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2015-06-18 09:49:14 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 2014-09-15. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6Z14 for the date range from 2014-09-15 to 2014-12-15. | 2015-06-18 09:49:15 Checking Daily data file for symbol 6E.20150300.CME_Fo for the date range from 2014-12-15 to 2015-03-16. | 2015-06-18 09:49:15 Checking Daily data file for symbol 6E.20150600.CME_Fo for the date range from 2015-03-16 to 2015-06-15. | 2015-06-18 09:49:15 Checking Daily data file for symbol 6E.20150900.CME_Fo for the date range from 2015-06-15 to 2015-06-18. | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10 | Symbols used for continuous contract chart: | 2015-06-18 09:49:15 6E.20121200.CME_Fo | 2015-06-18 09:49:15 6E.20130300.CME_Fo | 2015-06-18 09:49:15 6E.20130600.CME_Fo | 2015-06-18 09:49:15 6E.20130900.CME_Fo | 2015-06-18 09:49:15 6E.20131200.CME_Fo | 2015-06-18 09:49:15 6E.20140300.CME_Fo | 2015-06-18 09:49:15 6E.20140600.CME_Fo | 2015-06-18 09:49:15 6E.20140900.CME_Fo | 2015-06-18 09:49:15 6E.20141200.CME_Fo | 2015-06-18 09:49:15 6E.20150300.CME_Fo | 2015-06-18 09:49:15 6E.20150600.CME_Fo | 2015-06-18 09:49:15 6E.20150900.CME_Fo | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Checking for volume based rollover dates. | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20121200.CME_Fo to 6E.20130300.CME_Fo occurs at 2012-12-14 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20140600.CME_Fo to 6E.20140900.CME_Fo occurs at 2014-06-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20140900.CME_Fo to 6E.20141200.CME_Fo occurs at 2014-09-12 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20141200.CME_Fo to 6E.20150300.CME_Fo occurs at 2014-12-12 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20150300.CME_Fo to 6E.20150600.CME_Fo occurs at 2015-03-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20150600.CME_Fo to 6E.20150900.CME_Fo occurs at 2015-06-12 | 2015-06-18 09:49:15 Date rule based rollover from 6E.20121200.CME_Fo to next contract occurs at 2012-12-17. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20141200.CME_Fo to next contract occurs at 2014-12-15. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20150300.CME_Fo to next contract occurs at 2015-03-16. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20150600.CME_Fo to next contract occurs at 2015-06-15. | 2015-06-18 09:49:15 Date rule based rollover from 6E.20150900.CME_Fo to next contract occurs at 2015-09-14. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-17. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-18. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-17. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-16. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 2014-09-15. | 2015-06-18 09:49:15 Checking Daily data file for symbol E6Z14 for the date range from 2014-09-15 to 2014-12-15. | 2015-06-18 09:49:15 Checking Daily data file for symbol 6E.20150300.CME_Fo for the date range from 2014-12-15 to 2015-03-16. | 2015-06-18 09:49:15 Checking Daily data file for symbol 6E.20150600.CME_Fo for the date range from 2015-03-16 to 2015-06-15. | 2015-06-18 09:49:15 Checking Daily data file for symbol 6E.20150900.CME_Fo for the date range from 2015-06-15 to 2015-06-18. | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10 | Symbols used for continuous contract chart: | 2015-06-18 09:49:15 6E.20121200.CME_Fo | 2015-06-18 09:49:15 6E.20130300.CME_Fo | 2015-06-18 09:49:15 6E.20130600.CME_Fo | 2015-06-18 09:49:15 6E.20130900.CME_Fo | 2015-06-18 09:49:15 6E.20131200.CME_Fo | 2015-06-18 09:49:15 6E.20140300.CME_Fo | 2015-06-18 09:49:15 6E.20140600.CME_Fo | 2015-06-18 09:49:15 6E.20140900.CME_Fo | 2015-06-18 09:49:15 6E.20141200.CME_Fo | 2015-06-18 09:49:15 6E.20150300.CME_Fo | 2015-06-18 09:49:15 6E.20150600.CME_Fo | 2015-06-18 09:49:15 6E.20150900.CME_Fo | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Checking for volume based rollover dates. | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20121200.CME_Fo to 6E.20130300.CME_Fo occurs at 2012-12-14 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20140600.CME_Fo to 6E.20140900.CME_Fo occurs at 2014-06-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20140900.CME_Fo to 6E.20141200.CME_Fo occurs at 2014-09-12 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20141200.CME_Fo to 6E.20150300.CME_Fo occurs at 2014-12-12 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20150300.CME_Fo to 6E.20150600.CME_Fo occurs at 2015-03-13 | 2015-06-18 09:49:15 6E.20150900.CME_Fo [CV] Weekly #10: Volume based rollover from 6E.20150600.CME_Fo to 6E.20150900.CME_Fo occurs at 2015-06-12 | 2015-06-18 09:49:15 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 09:51:20 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20141200.CME_Fo to next contract occurs at 2014-12-15. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20150300.CME_Fo to next contract occurs at 2015-03-16. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20150600.CME_Fo to next contract occurs at 2015-06-15. | 2015-06-18 09:58:19 Date rule based rollover from 6E.20150900.CME_Fo to next contract occurs at 2015-09-14. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-17. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-16. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 2014-09-15. | 2015-06-18 09:58:19 Checking Daily data file for symbol E6Z14 for the date range from 2014-09-15 to 2014-12-15. | 2015-06-18 09:58:19 Checking Daily data file for symbol 6E.20150300.CME_Fo for the date range from 2014-12-15 to 2015-03-16. | 2015-06-18 09:58:19 Checking Daily data file for symbol 6E.20150600.CME_Fo for the date range from 2015-03-16 to 2015-06-15. | 2015-06-18 09:58:19 Checking Daily data file for symbol 6E.20150900.CME_Fo for the date range from 2015-06-15 to 2015-06-18. | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4 | Symbols used for continuous contract chart: | 2015-06-18 09:58:19 6E.20130600.CME_Fo | 2015-06-18 09:58:19 6E.20130900.CME_Fo | 2015-06-18 09:58:19 6E.20131200.CME_Fo | 2015-06-18 09:58:19 6E.20140300.CME_Fo | 2015-06-18 09:58:19 6E.20140600.CME_Fo | 2015-06-18 09:58:19 6E.20140900.CME_Fo | 2015-06-18 09:58:19 6E.20141200.CME_Fo | 2015-06-18 09:58:19 6E.20150300.CME_Fo | 2015-06-18 09:58:19 6E.20150600.CME_Fo | 2015-06-18 09:58:19 6E.20150900.CME_Fo | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Checking for volume based rollover dates. | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140600.CME_Fo to 6E.20140900.CME_Fo occurs at 2014-06-13 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140900.CME_Fo to 6E.20141200.CME_Fo occurs at 2014-09-12 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20141200.CME_Fo to 6E.20150300.CME_Fo occurs at 2014-12-12 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20150300.CME_Fo to 6E.20150600.CME_Fo occurs at 2015-03-13 | 2015-06-18 09:58:19 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20150600.CME_Fo to 6E.20150900.CME_Fo occurs at 2015-06-12 | 2015-06-18 09:58:19 CTS FIX: Received Market RFQ collateral report. | 2015-06-18 10:08:41 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:18:03 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:32:42 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:36:05 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:43:51 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:44:51 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:45:06 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 10:45:22 CTS FIX: Received Market RFQ collateral report. | 2015-06-18 10:45:50 CTS FIX: Received Market RFQ collateral report. | 2015-06-18 10:51:40 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 11:05:16 CTS FIX: Requesting Open Orders for account: 7G* | 2015-06-18 11:15:29 CTS FIX: Received Account List collateral report. | 2015-06-18 11:15:29 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 11:21:01 CTS FIX: Received Market RFQ collateral report. | 2015-06-18 12:11:28 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 12:25:21 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 12:31:43 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 13:32:14 CTS FIX: Received Exchange Notification collateral report. | 2015-06-18 13:35:43 CTS T4 FIX | Starting real-time market data updates for: NQ.20150900.CME_Eq. ID: 52 | 2015-06-18 13:53:17 Intraday data recording state for symbol NQ.20150900.CME_Eq is set to download pending. | 2015-06-18 13:53:17 HD Request # 35 | Downloading Intraday chart data for NQ.20150900.CME_Eq to the file NQ.20150900.CME_Eq.scid. Service: cts | 2015-06-18 13:53:17 HD Request # 35 | Download start Date-Time: 2015-06-16 20:02:57.0 | 2015-06-18 13:53:17 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2015-06-18 13:53:17 HD Request # 36 | Downloading Historical Daily chart data for NQ.20150900.CME_Eq. Starting date: 2015-06-15. Service: cts | 2015-06-18 13:53:17 HD Request # 36 | Requesting historical Daily data for NQU15 starting at 2015-06-14 | 2015-06-18 13:53:17 CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 69.44.110.227 | 2015-06-18 13:53:17 CTS T4 FIX | Starting real-time market data updates for: YM.20150600.CME_E. ID: 53 | 2015-06-18 13:53:17 CTS T4 FIX | Sending security definition request for symbol NQ.20150900.CME_Eq | 2015-06-18 13:53:17 CTS T4 FIX | Starting real-time market data updates for: ES.20150600.CME_Eq. ID: 54 | 2015-06-18 13:53:17 CTS T4 FIX | Starting real-time market data updates for: NQ.20150600.CME_Eq. ID: 55 | 2015-06-18 13:53:17 CTS T4 FIX | Starting real-time market data updates for: TF.20150600.ICE_IN. ID: 56 | 2015-06-18 13:53:17 Intraday data recording state for symbol TF.20150600.ICE_IN is set to download pending. | 2015-06-18 13:53:17 HD Request # 37 | Downloading Intraday chart data for TF.20150600.ICE_IN to the file TF.20150600.ICE_IN.scid. Service: ice.us | 2015-06-18 13:53:17 HD Request # 37 | Download start Date-Time: 2015-06-16 19:47:15.0 | 2015-06-18 13:53:17 HD Request # 37 | Using server: scdf1.sierracharts.com port 10149 | 2015-06-18 13:53:17 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-06-18 13:53:17 CTS FIX Historical Data socket (18) | Connected. | 2015-06-18 13:53:17 CTS FIX Historical Data socket (18) | Starting SSL connection. | 2015-06-18 13:53:17 CTS T4 FIX | Received matching security definition for symbol NQ.20150900.CME_Eq. Subscribing to data. | 2015-06-18 13:53:17 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2015-06-18 13:53:17 Socket (19) | Connected. | 2015-06-18 13:53:17 HD Request # 37 | Sending historical data logon request message. | 2015-06-18 13:53:17 HD Request # 36 | Receiving historical Daily data for NQ.20150900.CME_Eq starting at 2015-06-15 | 2015-06-18 13:53:17 Writing historical Daily data for NQ.20150900.CME_Eq to the file NQ.20150900.CME_Eq.dly | 2015-06-18 13:53:17 HD Request # 36 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 4 records for NQ.20150900.CME_Eq | 2015-06-18 13:53:17 HD Request # 37 | Requesting Intraday data. Start Date-Time: 2015-06-16 19:47:15. Record interval: 1. Symbol: RJM15 | 2015-06-18 13:53:17 HD Request # 37 | Decompressing data. | 2015-06-18 13:53:17 HD Request # 37 | Receiving Intraday data for TF.20150600.ICE_IN starting at 2015-06-16 19:47:15 | 2015-06-18 13:53:17 HD Request # 37 | Timestamp of first Intraday data file record written: 2015-06-16 19:47:15 | 2015-06-18 13:53:17 HD Request # 36 | Daily download COMPLETE for NQ.20150900.CME_Eq. Completion time: 0s. Unique request ID: 35 | 2015-06-18 13:53:17 Removed historical data download ID 35 | 2015-06-18 13:53:17 HD Request # 38 | Downloading Historical Daily chart data for NQ#. Starting date: 2015-06-15. Service: cts | 2015-06-18 13:53:17 HD Request # 38 | Requesting historical Daily Continuous data for NQZ10 starting at 2015-06-14 | 2015-06-18 13:53:17 CTS FIX Historical Data socket (18) | SSL connection established. | 2015-06-18 13:53:17 HD Request # 38 | Receiving historical Daily data for NQ# starting at 2015-06-15 | 2015-06-18 13:53:17 Writing historical Daily data for NQ# to the file NQ#.dly | 2015-06-18 13:53:17 HD Request # 38 | Received 4 records from 2015-06-15 00:00:00 to 2015-06-18 00:00:00 (4.0 days) and wrote 4 records for NQ# | 2015-06-18 13:53:17 HD Request # 38 | Daily download COMPLETE for NQ#. Completion time: 0s. Unique request ID: 36 | 2015-06-18 13:53:17 Removed historical data download ID 36 | 2015-06-18 13:53:17 Socket (19) | Shutdown and closed. | 2015-06-18 13:53:17 The network socket for historical data has been closed. | 2015-06-18 13:53:17 HD Request # 37 | Received 4241 records from 2015-06-16 19:47:15 to 2015-06-18 13:38:07 (41.8 hours) and wrote 4241 records for TF.20150600.ICE_IN | 2015-06-18 13:53:17 HD Request # 37 | Intraday download COMPLETE for TF.20150600.ICE_IN. Completion time: 0s. Unique request ID: 37 | 2015-06-18 13:53:17 Removed historical data download ID 37 | 2015-06-18 13:53:17 Real-time Intraday chart data file updates started for TF.20150600.ICE_IN | 2015-06-18 13:53:17 CTS FIX Historical Data: Sending the Logon message. | 2015-06-18 13:53:17 CTS FIX Historical Data: Connected to Historical data server. | 2015-06-18 13:53:17 HD Request # 35 | Requesting historical Tick data for NQ.20150900.CME_Eq from 2015-06-16 00:00:00 to 2015-06-16 00:00:00 (US Central Time). | 2015-06-18 13:53:17 CTS T4 FIX | Sending security definition request for symbol ES.20150600.CME_Eq | 2015-06-18 13:53:18 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Subscribing to data. | 2015-06-18 13:53:18 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2015-06-18 13:53:18 HD Request # 35 | Receiving Intraday data for NQ.20150900.CME_Eq starting at 2015-06-15 17:00:00 | 2015-06-18 13:53:19 HD Request # 35 | Total records received: 98143 | 2015-06-18 13:53:19 HD Request # 35 | Requesting historical Tick data for NQ.20150900.CME_Eq from 2015-06-17 00:00:00 to 2015-06-17 00:00:00 (US Central Time). | 2015-06-18 13:53:19 CTS T4 FIX | Sending security definition request for symbol NQ.20150600.CME_Eq | 2015-06-18 13:53:19 CTS T4 FIX | Received matching security definition for symbol NQ.20150600.CME_Eq. Subscribing to data. | 2015-06-18 13:53:19 CTS T4 FIX | Received 1 security definitions for underlying symbol NQ | 2015-06-18 13:53:19 CTS T4 FIX | Sending security definition request for symbol TF.20150600.ICE_IN | 2015-06-18 13:53:21 CTS T4 FIX | Received matching security definition for symbol TF.20150600.ICE_IN. Subscribing to data. | 2015-06-18 13:53:21 CTS T4 FIX | Received 1 security definitions for underlying symbol TF | 2015-06-18 13:53:21 HD Request # 35 | Timestamp of first Intraday data file record written: 2015-06-16 20:03:59 | 2015-06-18 13:53:21 HD Request # 35 | Total records received: 219625 | 2015-06-18 13:53:22 HD Request # 35 | Requesting historical Tick data for NQ.20150900.CME_Eq from 2015-06-18 00:00:00 to 2015-06-18 00:00:00 (US Central Time). | 2015-06-18 13:53:22 CTS T4 FIX | Sending security definition request for symbol YM.20150600.CME_E | 2015-06-18 13:53:22 CTS T4 FIX | Received matching security definition for symbol YM.20150600.CME_E. Subscribing to data. | 2015-06-18 13:53:22 CTS T4 FIX | Received 1 security definitions for underlying symbol YM | 2015-06-18 13:53:22 HD Request # 35 | Total records received: 343062 | 2015-06-18 13:53:25 HD Request # 35 | Requesting historical Tick data for NQ.20150900.CME_Eq from 2015-06-19 00:00:00 to 2015-06-19 00:00:00 (US Central Time). | 2015-06-18 13:53:25 HD Request # 35 | Total records received: 343062 | 2015-06-18 13:53:25 HD Request # 35 | Requesting historical Tick data for NQ.20150900.CME_Eq from 2015-06-20 00:00:00 to 2015-06-20 00:00:00 (US Central Time). | 2015-06-18 13:53:25 HD Request # 35 | Received 343062 records from 2015-06-15 17:00:00 to 2015-06-18 13:53:21 (2.9 days) and wrote 244145 records for NQ.20150900.CME_Eq | 2015-06-18 13:53:25 Added 3 Time and Sales records to Intraday data file for NQ.20150900.CME_Eq after download. | 2015-06-18 13:53:25 HD Request # 35 | Intraday download COMPLETE for NQ.20150900.CME_Eq. Completion time: 8s. Unique request ID: 34 | 2015-06-18 13:53:25 Removed historical data download ID 34 | 2015-06-18 13:53:25 Real-time Intraday chart data file updates started for NQ.20150900.CME_Eq | 2015-06-18 13:53:25 CTS FIX Historical Data socket (18) | Closed. No error. | 2015-06-18 13:54:25 CTS FIX Historical Data socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2015-06-18 13:54:25 CTS FIX Historical Data socket (18) | SSL has been shut down. | 2015-06-18 13:54:25 CTS FIX Historical Data socket (18) | SSL object has been freed. SSL state is now disconnected. | 2015-06-18 13:54:25 CTS FIX Historical Data socket (18) | Shutdown and closed. | 2015-06-18 13:54:25 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2015-06-18 13:54:25 CTS FIX Historical Data: Disconnected. | 2015-06-18 13:54:25 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20141200.CME_Fo to next contract occurs at 2014-12-15. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20150300.CME_Fo to next contract occurs at 2015-03-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20150600.CME_Fo to next contract occurs at 2015-06-15. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20150900.CME_Fo to next contract occurs at 2015-09-14. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-17. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 2014-09-15. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6Z14 for the date range from 2014-09-15 to 2014-12-15. | 2015-06-18 14:55:01 Checking Daily data file for symbol 6E.20150300.CME_Fo for the date range from 2014-12-15 to 2015-03-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol 6E.20150600.CME_Fo for the date range from 2015-03-16 to 2015-06-15. | 2015-06-18 14:55:01 Checking Daily data file for symbol 6E.20150900.CME_Fo for the date range from 2015-06-15 to 2015-06-18. | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4 | Symbols used for continuous contract chart: | 2015-06-18 14:55:01 6E.20130600.CME_Fo | 2015-06-18 14:55:01 6E.20130900.CME_Fo | 2015-06-18 14:55:01 6E.20131200.CME_Fo | 2015-06-18 14:55:01 6E.20140300.CME_Fo | 2015-06-18 14:55:01 6E.20140600.CME_Fo | 2015-06-18 14:55:01 6E.20140900.CME_Fo | 2015-06-18 14:55:01 6E.20141200.CME_Fo | 2015-06-18 14:55:01 6E.20150300.CME_Fo | 2015-06-18 14:55:01 6E.20150600.CME_Fo | 2015-06-18 14:55:01 6E.20150900.CME_Fo | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Checking for volume based rollover dates. | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140600.CME_Fo to 6E.20140900.CME_Fo occurs at 2014-06-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140900.CME_Fo to 6E.20141200.CME_Fo occurs at 2014-09-12 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20141200.CME_Fo to 6E.20150300.CME_Fo occurs at 2014-12-12 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20150300.CME_Fo to 6E.20150600.CME_Fo occurs at 2015-03-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20150600.CME_Fo to 6E.20150900.CME_Fo occurs at 2015-06-12 | 2015-06-18 14:55:01 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20141200.CME_Fo to next contract occurs at 2014-12-15. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20150300.CME_Fo to next contract occurs at 2015-03-16. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20150600.CME_Fo to next contract occurs at 2015-06-15. | 2015-06-18 14:55:01 Date rule based rollover from 6E.20150900.CME_Fo to next contract occurs at 2015-09-14. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-17. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 2014-09-15. | 2015-06-18 14:55:01 Checking Daily data file for symbol E6Z14 for the date range from 2014-09-15 to 2014-12-15. | 2015-06-18 14:55:01 Checking Daily data file for symbol 6E.20150300.CME_Fo for the date range from 2014-12-15 to 2015-03-16. | 2015-06-18 14:55:01 Checking Daily data file for symbol 6E.20150600.CME_Fo for the date range from 2015-03-16 to 2015-06-15. | 2015-06-18 14:55:01 Checking Daily data file for symbol 6E.20150900.CME_Fo for the date range from 2015-06-15 to 2015-06-18. | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4 | Symbols used for continuous contract chart: | 2015-06-18 14:55:01 6E.20130600.CME_Fo | 2015-06-18 14:55:01 6E.20130900.CME_Fo | 2015-06-18 14:55:01 6E.20131200.CME_Fo | 2015-06-18 14:55:01 6E.20140300.CME_Fo | 2015-06-18 14:55:01 6E.20140600.CME_Fo | 2015-06-18 14:55:01 6E.20140900.CME_Fo | 2015-06-18 14:55:01 6E.20141200.CME_Fo | 2015-06-18 14:55:01 6E.20150300.CME_Fo | 2015-06-18 14:55:01 6E.20150600.CME_Fo | 2015-06-18 14:55:01 6E.20150900.CME_Fo | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Checking for volume based rollover dates. | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140600.CME_Fo to 6E.20140900.CME_Fo occurs at 2014-06-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20140900.CME_Fo to 6E.20141200.CME_Fo occurs at 2014-09-12 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20141200.CME_Fo to 6E.20150300.CME_Fo occurs at 2014-12-12 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20150300.CME_Fo to 6E.20150600.CME_Fo occurs at 2015-03-13 | 2015-06-18 14:55:01 6E.20150900.CME_Fo [CV] Weekly #4: Volume based rollover from 6E.20150600.CME_Fo to 6E.20150900.CME_Fo occurs at 2015-06-12 | 2015-06-18 14:55:01 CTS FIX: Requesting Open Orders for account: 7G* | 2015-06-18 15:15:29 CTS FIX: Received Account List collateral report. | 2015-06-18 15:15:29 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6E#.dly | 2015-06-18 16:03:55 HD Request # 39 | Downloading Historical Daily chart data for 6E#. Starting date: 1965-06-18. Service: cts | 2015-06-18 16:03:55 HD Request # 39 | Error downloading historical Daily data for 6E#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 16:03:55 * HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E# | 2015-06-18 16:03:55 HD Request # 39 | Daily download COMPLETE for 6E#. Completion time: 0s. Unique request ID: 38 | 2015-06-18 16:03:55 Removed historical data download ID 38 | 2015-06-18 16:03:55 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6E#.dly | 2015-06-18 16:03:55 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:06:17 HD Request # 40 | Downloading Historical Daily chart data for E6#. Starting date: 1965-06-18. Service: cts | 2015-06-18 16:06:17 HD Request # 40 | Error downloading historical Daily data for E6#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 16:06:17 * HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for E6# | 2015-06-18 16:06:17 HD Request # 40 | Daily download COMPLETE for E6#. Completion time: 0s. Unique request ID: 39 | 2015-06-18 16:06:17 Removed historical data download ID 39 | 2015-06-18 16:06:17 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:06:18 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:10:02 HD Request # 41 | Downloading Historical Daily chart data for E6#. Starting date: 1965-06-18. Service: cts | 2015-06-18 16:10:02 HD Request # 41 | Error downloading historical Daily data for E6#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 16:10:02 * HD Request # 41 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for E6# | 2015-06-18 16:10:02 HD Request # 41 | Daily download COMPLETE for E6#. Completion time: 0s. Unique request ID: 40 | 2015-06-18 16:10:02 Removed historical data download ID 40 | 2015-06-18 16:10:02 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:10:02 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:14:15 HD Request # 42 | Downloading Historical Daily chart data for E6#. Starting date: 1965-06-18. Service: cts | 2015-06-18 16:14:15 HD Request # 42 | Error downloading historical Daily data for E6#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 16:14:15 * HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for E6# | 2015-06-18 16:14:15 HD Request # 42 | Daily download COMPLETE for E6#. Completion time: 0s. Unique request ID: 41 | 2015-06-18 16:14:15 Removed historical data download ID 41 | 2015-06-18 16:14:15 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:14:15 HD Request # 43 | Downloading Historical Daily chart data for E6#. Starting date: 1965-06-18. Service: cts | 2015-06-18 16:14:57 HD Request # 43 | Error downloading historical Daily data for E6#. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-06-18 16:14:57 * HD Request # 43 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for E6# | 2015-06-18 16:14:57 HD Request # 43 | Daily download COMPLETE for E6#. Completion time: 0s. Unique request ID: 42 | 2015-06-18 16:14:57 Removed historical data download ID 42 | 2015-06-18 16:14:57 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\E6#.dly | 2015-06-18 16:14:57 |
[2015-06-19 02:54:55] |
Your installation of Sierra Chart must have had an old symbol setting which supported these symbols with the #. We have added that symbol setting back, but it is a little different and requires the latest prerelease to support E6#. This will be out today or tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-19 02:55:20
