Date/Time: Sat, 23 Nov 2024 00:16:13 +0000
mouse sloppy focus
View Count: 1650
[2013-06-06 20:06:18] |
sleepless2 - Posts: 4 |
Hi, I like to use the global cross-hair cursor to compare charts. My chartbooks are made of multiple charts next to each other. The problem I have is that as I roll the mouse cursor around my chartbook all the charts horizontal time positions keep jumping around. Is there someway of having the cross hair cursos only follow you if you click on the chart ? (Instead of the current "sloppy" focus setting where you do not select a chart to have the cursor on) Thanks |
[2013-06-06 22:29:03] |
Sierra Chart - Max - Posts: 5730 |
You will want to disable the Synchronization feature by selecting Tools >> Synchronize Charts: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartValues If you still want to have Tools >> Synchronize Charts enabled, you are able to click on the chart to enable the Chart Values tool, then click again to disable the tool and move around. Sierra Chart Support Date Time Of Last Edit: 2013-06-13 04:05:28
