Date/Time: Sun, 08 Sep 2024 00:16:35 +0000
Drawings move
View Count: 784
[2015-06-18 13:14:02] |
User28682 - Posts: 233 |
Sometimes when I use the extending rectangle tool to draw an area on a volume by price chart,I come in the next day, open the program and the drawing area has moved...all of them do on the same graph? Any idea why? Thanks Tom |
[2015-06-18 16:28:15] |
Refer to help topic 34 here: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html Sierra Chart Support |
[2015-06-18 17:46:01] |
If you need more help, we need to see an image of the chart. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
