Date/Time: Mon, 21 Sep 2026 10:36:56 +0000
Alert for Quote Board
View Count: 1207
| [2015-06-18 11:08:10] |
| User93757 - Posts: 61 |
Hi, The quote board currently has "Add Symbol Alert"; currently you can add a numerical entry to the Value Field. Would it be possible to allow the user to enter a value based on a current field in the quote board? And is it possible to auto rearm the alert. In otherwords, what i would like to do is create a audible sound every time we hit a new high of the day, ie. Field = "last" Comparison = "Equal To" Value = "{HIGH}"; then auto rearm the alert. Therefore, you would not have to run many charts for simple alerts, where the value already has a comparison in the quote board. thx, |
| [2015-06-18 19:46:39] |
There are no plans for this first suggestion. It is necessary to use Simple Alerts within the chart itself. We will add a new option for Symbol Alerts to support continuous monitoring so they do not have to be re-enabled after they are triggered. The terminology arm/disarm has been changed to enable/disable. "Arm" is much too strong of a term for an alert. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
