Date/Time: Sun, 08 Sep 2024 00:16:22 +0000
Bund daily chart does not update during the day
View Count: 795
[2015-06-18 09:36:50] |
User895955 - Posts: 2 |
Eurex and Liffe daily charts wont add a new bar until the end of the day. If I look at cbot contracts they already have a bar in for today June 18th in delayed mode, whilst the European contracts have no bar for today. Why is this and can it be changed ? Many thanks Paul Date Time Of Last Edit: 2015-06-18 09:37:39
[2015-06-18 09:47:47] |
If they do not update when you select Edit >> Download Data-Historical Chart, then the data is not available until the end of the day. What the reason is, we are not sure specifically other than the exchanges do not make the data available earlier. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-18 11:15:46] |
Yet the intra day charts such as 5 minutes and hourly charts do update through out the day ?
