Date/Time: Sun, 08 Sep 2024 00:05:00 +0000
trade DOM buttons
View Count: 1045
[2015-06-18 01:19:44] |
trader1 - Posts: 128 |
Hi, Is there a way to assign a specified size to each of the numbered buttons on the trade DOM? Thanks. |
[2015-06-18 05:04:32] |
Yes. This can be done through the Set tab of the Trade Window. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderQuantityButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
