Date/Time: Sun, 08 Sep 2024 00:03:34 +0000
hand /cross hair issue
View Count: 772
[2015-06-17 20:00:52] |
User81627 - Posts: 1 |
Is it possible to have a cross hair/hand feature at once like for example in think or swim. it is annoying having to switch back and forth thank you.
[2015-06-17 21:40:44] |
Yes. Enable the option to have the Chart Values tool Always On when Using Other Tools. It is documented here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
