Date/Time: Sun, 08 Sep 2024 00:16:21 +0000
question about chart based on volume filtering data
View Count: 737
[2015-06-17 17:08:53] |
User479536 - Posts: 2 |
Hello, is there anyway to create a chart that is based off of orders that have a volume of x or higher? Example, if I want a ES chart that only considers date from trade with 100 or greater volume, can this be done
[2015-06-17 17:19:30] |
Yes. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VolumeFilterH Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
