Date/Time: Sun, 27 Sep 2026 14:35:02 +0000
Trade orders and position IB FA
View Count: 1100
| [2015-06-17 15:12:12] |
| User70302 - Posts: 30 |
Hi, I use an IB FA account with SC. Under Trade - Trade orders and positions there are no orders and no balances displayed. Positions are shown though. I would like to see the orders as well, if possible. Thanks. |
| [2015-06-17 16:38:35] |
Were these orders sent from Sierra Chart? If not, then select Global Settings >> Data/Trade Service Settings and set the Instance to Client ID 0. After this reconnect to TWS with File >> Disconnect and File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-06-17 16:52:00] |
Orders were entered in TWS. After changing the cliend ID to 0 SC the connection to TWS fails. |
| [2015-06-17 17:07:22] |
Fixed. Everything works now, thank you.
| [2015-06-17 17:13:12] |
Do you have any other program connected to TWS? This would probably be why the connection fails.
