Date/Time: Sun, 22 Dec 2024 11:23:55 +0000
Alert for Ichimoku Crossover
View Count: 1268
[2015-06-16 22:11:09] |
User85876 - Posts: 15 |
Is there a way to get an alert when the Tenkan-Sen crosses the Kijun-Sen?
[2015-06-17 00:44:52] |
Have you looked at this page first: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
