Date/Time: Sun, 22 Dec 2024 11:06:37 +0000
DOM data
View Count: 802
[2015-06-16 16:37:34] |
User76749 - Posts: 8 |
Please, how can I set more levels of DOM data on my chart? I have only one level (at the current price - plese see attached screen) and I would like to set for example 5 levels for Bid and 5 levels for Ask site? Thank you!
[2015-06-16 17:50:23] |
Go to File >> Open Market Depth Window. Do you see just one level of depth there?
[2015-06-16 18:26:51] |
Yes.
[2015-06-16 18:30:24] |
Then this indicates you do not have access to market depth data from Interactive Brokers for that particular exchange or you have exceeded the limit on the number of symbols you can get market depth data for. Refer to: https://www.sierrachart.com/index.php?page=doc/IB.php#MarketDepth Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
