Date/Time: Sun, 22 Dec 2024 11:20:44 +0000
Study not showing in real time
View Count: 879
[2015-06-16 16:08:50] |
User53601 - Posts: 105 |
The ACSIL study is showing its values correctly just after loading the chart. Hovever, during real time trading or replay, the ACSIL study is not displaying its values. The sc.AutoLoop is set to 1. Could you please give some navigation which way to look to find the reason of the issue. thank you |
[2015-06-16 18:12:21] |
Our recommendation is to start with a very simple study. For example, calculating a moving average and when that is working properly for you, gradually make changes until you see the problem to determine the source of the problem.
[2015-06-19 09:33:05] |
issue solved, thank you
