Date/Time: Wed, 16 Sep 2026 02:57:52 +0000
U.S. Equities vs BATS
View Count: 1136
| [2015-06-16 00:25:53] |
| Kinobe - Posts: 86 |
hi what is the difference between Us equities and BATS data exchange? quality, speed, volume? thank you |
| [2015-06-16 18:06:10] |
We did a comparison, the BATS volume is significantly less than US Equities . In regards to speed, we would not think there would be much difference. Not really certain what is meant by "quality" . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-16 18:06:55
| [2015-06-17 12:55:56] |
thank you, very appreciated. by quality, I mean tick by tick data are the same in the same time ? latency data between these 2 feeds? |
| [2015-06-17 16:45:36] |
There definitely are going to be difference between the trades between these two data feeds. They are different exchanges. We do not think there is any difference regarding latency. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
