Date/Time: Sun, 22 Dec 2024 11:43:34 +0000
spreadsheet is miscalculating
View Count: 1215
[2015-06-15 21:07:02] |
jivetrader - Posts: 410 |
K903 should return FALSE because E903=B903. what is wrong with Spreadsheets? |
spreadsheet wrong calc2.png / V - Attached On 2015-06-15 21:05:31 UTC - Size: 101.23 KB - 391 views |
[2015-06-16 04:25:44] |
They may not be exactly equal. Select the cells being referenced and select Spreadsheet >>Number Format. Increase the number of decimal places and see if the values actually match.
[2015-06-16 23:30:26] |
Sawtooth - Posts: 4141 |
Here's what I do to eliminate floating point errors so that values can be accurately compared with formulas: http://www.sawtoothtrade.com/example-3.html |
[2015-06-16 23:49:02] |
thank you tomg! i figured some kind of rounding was in order. would be nice if sierra didnt have these kind of 'invisible' issues.... |
