Date/Time: Sun, 22 Dec 2024 10:03:33 +0000
Studies as QuoteBoard Fields
View Count: 1241
[2015-06-15 17:53:36] |
User16114 - Posts: 153 |
Is it possible to have the Cumulative Volume Ratio (SG2 from the Relative Volume Study) a Field (column) in a QuoteBoard.
[2015-06-15 18:43:58] |
No. This is not supported. Refer to: Displaying a Table of Study Values on a Spreadsheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
