Date/Time: Sun, 22 Dec 2024 10:28:28 +0000
VP for Ladder
View Count: 889
[2015-06-15 16:16:46] |
User106278 - Posts: 6 |
Is there a way to set up "volume by price" on the DOM to show total volume at price for set time sessions? Let's say every 30 mins as an example? So after 30 mins, vbp study starts a new profile with total volume at price beginning at zero. I'm trying to see volume profiles at shorter intraday session times. To me, reading smaller numbers as they accumulate is more easy to sink in than reading it when volume is at 10K+. I'm assuming that it can be set up on a chart, but I would prefer it to display on the DOM, where I do executions. Please advise on how to do this or alternative methods. Thanks! Much appreciated. |
[2015-06-15 19:04:07] |
This can be done, see the attached screenshot for settings.
VBP_Settings_2015-06-16_070253.png / V - Attached On 2015-06-15 19:03:31 UTC - Size: 21.1 KB - 386 views |
