Date/Time: Sun, 22 Dec 2024 10:01:44 +0000
No numbers bars data for YM-201509-ECBOT
View Count: 1678
[2015-06-15 13:57:10] |
Kefir - Posts: 34 |
Hi, numbers bars data are not being downloaded for YM-201509-ECBOT. Last date/time on my chart is 13-jun 9:30. NQ and ES are working fine. Any suggestions? Disconnecting / restarting SC didn't work IB data feed BR r Date Time Of Last Edit: 2015-06-15 14:05:36
[2015-06-15 17:50:54] |
In the case of Interactive Brokers the historical data does not contain the necessary data for Numbers Bars. When you open a new chart for that symbol, is it up-to-date and updating in real-time? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
