Date/Time: Sun, 12 Jan 2025 01:39:08 +0000
Question on Time Scale
View Count: 853
[2015-06-15 10:12:59]
User57584 - Posts: 30
I have hard time finding how to increase the span of the time scale on my screen, even though I have more than needed days loaded. For instance, on a 30mn chart, I cannot see more than one and a half month at once on the screen (I can see more obviously by scrolling the cursor or the mouse Wheel, but it's always limited to 1.5 month range from left to right of the screen).
Is this normal, or is there a way to compress the curve more?
Thank you in advance.
Jean-Marie Boulay
[2015-06-15 17:30:10]
Sierra Chart - Max - Posts: 5778
To see more bars on your Chart you will need to lower the Bar Spacing by using the (Down) arrow key on your keyboard. For more information and other methods to do this, refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing
Sierra Chart Support
Date Time Of Last Edit: 2015-06-15 18:24:57
[2015-06-16 09:50:22]
Thank you.
I well understand this and I am using these methods.
My point was to see whether it was possible to go further in the contraction of the candles to see a longer period of time in the past, at once on the screen, while staying on the same timescale.
It seems it cannot be done. Could you please confirm?
Jean-Marie Boulay
[2015-06-16 10:13:37]
No. You cannot reduce the bar spacing further. The next step is to increase the timeframe for the chart bars.
[2015-06-16 17:06:51]
Thank you very much.
JM Boulay
[2017-01-26 05:14:31]
SkyKeeper - Posts: 40
Hi, You can reduce the bar spacing?
[2017-01-26 10:07:00]
Yes. Refer to:
Working With Charts: Changing Bar Spacing
[2017-01-26 10:28:18]
You must be able to compress further.
For example, 1 second on the screen a few hours rather, than 40 minutes as it is now
