Date/Time: Sun, 22 Dec 2024 10:21:47 +0000
USDX
View Count: 814
[2015-06-15 05:58:17] |
jaban - Posts: 66 |
Hi there is a data mistake in the UDDX chart ( 2015-06-14 , 18:00 ) , but I cannot delete the file please have a look thanks |
[2015-06-15 06:16:27] |
This has now been corrected. Right-click before the incorrect data and select Delete and Download Data.
