Date/Time: Thu, 26 Dec 2024 11:11:18 +0000
entering orders at a speciifc price ysing chart trading
View Count: 1749
[2016-03-13 22:46:36]
User699694 - Posts: 49
Also when using replay I have it set to skip empty periods, but it still 'hangs' for a while an then starts again
Is that normal?
[2016-03-13 23:29:03]
Also
I understand that for autotrade bar based you have to disconnected from the data feed? Is that the same for autotrade replay, do you have to disconnect?
Also if you are running a chart that is referencing another chart, do both have to run in replay?
[2016-03-14 16:02:43]
The response for post #25 is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#SkippingData
Yes, this can be normal if the wait is less than 65 seconds.
Yes.
It depends. This is explained on this page here:
https://www.sierrachart.com/index.php?page=doc/doc_Backtesting.php
