Date/Time: Sun, 08 Sep 2024 00:16:23 +0000
Using sierra data with AMP trading
View Count: 909
[2015-06-14 23:36:27] |
User479525 - Posts: 22 |
I dont see the M after the symbol. How do I make sure that the data is sierra and as far as exchanges can i only use what my trading service has. Because on my sierra data account i have stocks does that get integrated with AMP.
[2015-06-15 00:58:26] |
We see you have activated the Sierra Chart Exchange Data Feed and the CME and US Equities exchanges on your bulina99 account. You need to log into Sierra Chart using that account to be able to access that data. Here are instructions: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Your Sierra Chart account will expire at the end of this month and you will need to pay for usage time on that account. The stock data from the Sierra Chart Exchange Data Feed is integrated with your AMP account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-18 23:30:25
[2015-06-15 01:03:19] |
ok thanks. can i get the custom study Trade29 that I have on my AC98662 account to bulina99 account please.
[2015-06-15 01:06:05] |
Yes this is no problem but you need to ask Trade29 to do this for you. You need to give them this new Account Name.
[2015-06-18 23:24:53] |
I have been trying to reach Trade29 this whole week to get the studies transferred to my new account and no response. Is there any way else to get this done. I really need those studies
[2015-06-19 04:54:09] |
We could do this, but we do not want to make this change without their permission. So we will contact them for you.
[2015-06-19 05:23:21] |
We have been informed that Trade 29 has now made this change. So restart Sierra Chart and you will have access to the Trade 29 studies.
