Date/Time: Sun, 22 Dec 2024 11:34:55 +0000
drawings import
View Count: 870
[2015-06-13 10:17:09] |
SKY - Posts: 45 |
Hi When importing drawing from chart X to chart Y – imported drawings (of chart X) make it impossible to use elements on chart Y as they overlap them Why not add a property to each drawing type called 'importable' (whatever its default setting will be) so if one wants avoid importing some drawing - the import can be avoided by setting importable=FALSE this way i can import X drawings to any other chart while controlling what is imported from it What do u think ? Tnx, Shuky |
[2015-06-16 18:07:58] |
We will see.
