Date/Time: Sun, 22 Dec 2024 10:47:00 +0000
Import A template
View Count: 2585
[2015-06-12 22:14:40] |
User639561 - Posts: 1 |
Hello I have been given a template by a friend and i would like to import it into my sieera chart but i do not know how. I have the file butcannot find any information on how to import a template many thanks Richard |
30M%20Profile%20Volume%20Delta%20v2(1).StdyCollct - Attached On 2015-06-12 22:13:51 UTC - Size: 65.25 KB - 470 views Attachment Deleted. |
[2015-06-13 01:49:07] |
This is a Study Collection file. You need to follow the instructions here to use this file: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html#UsingStudyCollection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-13 01:50:11
