Date/Time: Sun, 22 Dec 2024 10:22:34 +0000
Mr. Gene Sheldon
View Count: 1021
[2015-06-12 17:44:59] |
User72965 - Posts: 115 |
Can't move chart horizontally ?? Vertical ok ? In 2-3 charts in this chart book .... Rest Charts ok http://www.sierrachart.com/image.php?l=1434130736328.png Sending screen shot Best I think Hope it helps ~ Thx Gene |
[2015-06-12 19:03:28] |
Do the following: Uncheck Chart >> Lock Fill Space. Select Chart >> Go to End of Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-12 19:24:06] |
Did as you said :) Still not working Can't scroll sideways :( Sending log High five High five High Five ??? Don't know if that will help ?? Thx Gene :) Followed instructions Did it 2X to make sure all ok. Came up same High Five ? |
[2015-06-12 19:31:33] |
High five Thia another chart?? Goes sideways No up or down ???? Same chart book I unck.ed Fill Space Ene of chart ~~ Same as other one > Still not working ?? Gene :) |
[2015-06-12 19:33:06] |
Think I did wrong Trying again on Chart Image http://www.sierrachart.com/image.php?l=1434137344162.png |
[2015-06-14 11:54:58] |
We do not know what you have done with the configuration of that chart. We cannot help with it. Close that chart and open a new one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-14 11:55:18
