Date/Time: Sun, 22 Dec 2024 10:06:22 +0000
Tools
View Count: 849
[2015-06-12 15:54:46] |
fireworks11 - Posts: 63 |
Is there a way to have tools like the horizontal line tool be drawn underneath (!) the main price graph? If not can you add that possibility?
[2015-06-12 19:11:22] |
Yes. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-13 07:05:39] |
excellent!
