Date/Time: Sun, 22 Dec 2024 10:50:49 +0000
VBP - 1 Day Rollover Issue?
View Count: 899
[2015-06-12 13:58:16] |
infpz - Posts: 826 |
Left Chart: Daily Chart, Continuous Middle Chart: Daily Chart, non-Continuous Right Chart: 1440 minute chart Only far right one looks valid. Can you tell me why the volume bars on the others are all the same? Thanks, Patrick Z |
[2015-06-12 14:04:26] |
This is expected when using the Volume by Price study on a daily bar chart. This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#VolumePriceCalculations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-12 14:04:37
