Date/Time: Sun, 22 Dec 2024 10:55:45 +0000
Trade WIndow suggestion
View Count: 955
[2015-06-12 11:37:02]
phaedonk - Posts: 352
When TW is attached in a full screen chart there is huge wasted space on the bottom part. This forces to unnecessarily switch between the 2 most used tabs, Main and Targets. This is difficult when it is urgent to input targets and stop and send the order.
Suggestion: When TW is attached to full screen window, show the Main tab above and the Targets tab below.
If that is not possible, please find a way to combine some aspects of the two tabs. An order, above all else, needs a Quantity, a Target and a Stop. These should be in the same place.
Thanks.
[2015-06-13 02:02:39]
We will keep this in mind as we work on the Trade Window.
Also, the amount of space available depends upon the monitor size.
[2015-06-13 05:25:41]
Thank you.
True, about the monitor size, but nowadays most people have at least 24" monitors.
