Date/Time: Sun, 22 Dec 2024 15:47:59 +0000
Bar Numbering question
View Count: 892
[2015-06-12 02:56:35] |
buylosellhi - Posts: 60 |
Hi, I'd like to see the bar number of a particular bar plotted below the bar, like in the Bar Numbering study (pls see attached). But I dont want the number count to reset. Not sure what logic its following in the attached chart but I'd like to the numbers continuous without any session/day/week breaks. |
BarNumbering.PNG / V - Attached On 2015-06-12 02:56:29 UTC - Size: 82 KB - 328 views |
[2015-06-12 04:07:35] |
We will add a new input to the study to prevent resetting every day.
