Date/Time: Sun, 22 Dec 2024 09:57:52 +0000
View Count: 988
[2015-06-11 23:13:37]
Crtfyd - Posts: 278
Times and sales are only stored for the session. In other words if I close Sierra Charts, and reopen, I cant get those Time and Sales records back.
How do I save them to access them later?
Thx
[2015-06-12 04:28:27]
Actually they are saved other than the bid and ask quantities.
You just need to set Sierra Chart to a tick by tick data configuration:
https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
When you replay a chart you will see the time and sales data.
[2015-06-12 13:29:07]
Crtfyd - Posts: 278
Ive had it set to tic.
So I guess I don't understand the "replay" thing.
Can you direct me to that info.
thx
[2015-06-12 13:43:42]
Here are instructions to replay a chart:
https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#BasicInstructions
[2015-06-12 14:05:01]
Crtfyd - Posts: 278
What does this mean? (attached pic) I don't have any positions through Sierra Charts. Press Yes?
I don't want to lose any info. I made the mistake of taking the advice on the support info of changing my amount of "Time & Sales to Save" to 5,000 (from 15,000)to speed up Sierra charts, but now as you can see, I lost my opening Time and Sales, it only goes back to 9:34:01:023 after only 20 minutes of market open.
Or did I?
Will the Time and sales come back for when I opened my charts at 9:20? Or are they gone?
I only plan to save an amount for the opening hour, so I changed it back to 15,000 saved T&S.
Thx
Private File
[2015-06-12 14:18:04]
It is safe to press Yes.
When you perform a replay, you will see the time and sales data from that moment in time displayed in the Time and Sales window. So it is not lost.
[2015-06-12 14:32:26]
Crtfyd - Posts: 278
Thank you.
One more thing. The T&S is REALLY different from what I witnessed in real time. For instance, I noted about four (4) T&S over the volume of 2 (which I have filtered and shown by a yellow color)in real time. Now I see tons of yellow (>=2) amounts (see attached pic)
Private File
[2015-06-12 15:08:49]
It can be different if the historical data is re-downloaded in the chart.
Otherwise, we have insufficient information to answer the question.
