Date/Time: Sun, 22 Dec 2024 10:09:40 +0000
charting features
View Count: 855
[2015-06-11 18:10:56] |
User19874 - Posts: 1 |
Hello, 2 questions: 1) How to change the Dom Graph On Chart colors (the default color is too light for my background color? 2) How to enlarge and bold the menu and toolbar buttons on sierra main chart (I mean the first row with: File Edit Chart Analysis....and more) Thank U Sarit |
[2015-06-12 05:13:50] |
1. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph 2. This needs to be done through the Windows operating system. Changing the font of the ToolBar buttons can be done through Global Settings >> Graphics Settings on the newer versions of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
